Sun Visor Hits Mirror
Inthenoise
Robert
Maryland
2025 Outer Banks SAS
I know others have written about this but, lordy it's annoying. I've got a 2025 OB SAS. Every time I put my driver's-side visor down it knocks my rear view mirror out of position. Posting this because Ford has still not fixed for 2025. All it would take is removing a 1/2" or so from the visor, or relocating the mount, or something. On previous threads I've seen people say you just need to slide the visor over. Mine is at max and still does it. I'm 65, have driven many 100s of cars and never seen this. If anyone has a tip or hack I'm all ears. Thanks.
carrellslake
Oregon
2022 Ford Bronco
The mirror has two adjustment balls. The one by the glass is very stiff. They aren’t always adjusted well from the factory. If it helps, you can take the mirror off the windshield and adjust it before putting it back.
This - i didnt realize it until I saw it posted here a while ago too. That second articulation point helps a lot. Can twist it up over the camera hump and then still adjust and gets it up out of the way
KABQ
Aaron
Albuquerque, NM
You can shift the mirror to the right. I had the same problem until I figured this out
Inthenoise
Robert
Maryland
I will look at this. Thank you.
helifino16
Ron
Mount Sinai, NY (Long Island)
This came up a lot a few years ago. I'm surprised that folks are still finding this issue.
dgorsett
colorado
F250, Mustang, Explorer
First thing I do in a new car. That windshield pivot is always set wrong, usually too low to where the mirror blocks the windshield at an intersection
Squatch
I'm tall and with the steep windshield I hardly move the visor fully down. So, once every few months or so it happens and I think I'm going to adjust the mirror... never do. Then, I forget and the cycle repeats. 😂
DALOLA
Retired
Ohio 🇺🇸
'24 Mach-E, '22 Maverick, Hot Rods
Speaking of sun visors, (hijack coming...) does anyone have a hack for the 6"-8" it doesn't cover on the 2DR side glass, when fully extended? It's annoying AF because this is ALWAYS where the sun ends up coming thru.... 🤬
SkyKing
Boston, MA
'21 CG Wildtrak, E.R.A. Cobra 427 S/C
I use mine often and have never noticed this. Is everyone aware that the visors are telescopic and slide on the rod (so when you move the visor to block the side, you can slide it back to block the sun)? I am wondering if people are trying to close their visor while it is partially extended.
Squatch
Yes, we are(at least I am) aware of this technological marvel.
This issue, though, occurs when the visor is flipped up, normal, and you just flip it down and it hits the mirror. The rod is as far in the visor pocket as it will go.
I'll have to check if that happens with mine. I don't recall it ever being an issue since it slides on the rod.
Feasible fix could be a flap that folds out or a visor sleeve that you can pull to increase coverage.
I don't think making a multi-section extensible rod(like a retractable antenna or compact umbrella) would be worth the squeeze.
DALOLA
Retired
Ohio 🇺🇸
I'm assuming all the sun visors are the same, 2DR & 4DR. The 2DR door is considerably longer than a 4DR door, so this may not be an issue (or, as much of an issue..) on the 4DR. But fully extended, it falls 6-8" short of the length of the glass. I remember, I think some model Honda years ago, that had a little pull out extension in the visor, that would pick up another 4-5" after the extension rod was max'd. Something like that would be sweet.
Inthenoise
Robert
Maryland
Reasonable comment but yes, of course. If my visor is locked in place against the top, slid all the way to the left on the shaft, it still hits and moves the mirror when I rotate it down to cover the windshield. When I have time this week, I will fool around with some of the suggestions above. And, fyi, mine is a 4-door. Thanks, everyone for weighing in!
Inthenoise
Robert
Maryland
Keep a pad of post-it notes handy? lol.
