Subwoofer housing cracked…
B-Dog15
Brandon
Covington, Ky
2025 Base 4-Door
Didn’t think to get a picture while it was opened but….
I was having some rattling coming from the Subwoofer on my ‘25 Base Bronco caused by the top bolt being loose. I had already tightened the bolt before but it apparently wiggled loose again so I was going in and did one turn too much and cracked the top housing around the bolt… I’m still under warranty so I could just drop it off at my local dealership and have them replace it but I’m really not trying to not have my truck for a couple days while they wait for parts.
Any suggestions on how to manage this? I’m almost wondering if I should call the dealership and tell them what’s wrong and see if they can take a quick look, order the parts, and send me on my way until it gets in then schedule a time to bring it in and have it fixed while I wait since it shouldn’t be a long job. Any thoughts?
Valhalla
Valhalla
Chattanooga Tn
I think they will work with a scheduled look knowing you are driving it away.
CalvinT
Calvin
Phoenix, AZ
That's what I did with my door latch. Dealer looked at it, didn't have parts, ordered parts. I drove it home. They ordered part two weeks ago, they will install it in a couple of days.
The only time they should keep your Bronce while waiting for parts would be if it wasn't driveable because they have it torn apart. Now I know some on here seem to consider a Bronco without sound isn't driveable, hope you're not one of them.
B-Dog15
B-Dog15
Brandon
Covington, Ky
2025 Base 4-Door
That’s what I was thinking. And no sir if she can move she’s getting driven!
23OBX2.7
AB Canada
2023 Bronco
Do not mention that you touched anything no warranty just say it's cracked. Better to get tailgate sub and put mtx amp rack and amp in that spot...
B-Dog15
B-Dog15
Brandon
Covington, Ky
2025 Base 4-Door
For sure. My dealership has always been really good to me but don’t want to give them any reason at all to deny it under warranty!
If you wanted to fix it, it’s just plastic. Not hard to throw a couple of plastic welding staples at it and either heat meld or glue/epoxy on it
Dan-O
Dan
Fountain Hills, AZ
Like “Brian_B” said….i would just do a plastic weld fix to save time and trouble.
B-Dog15
B-Dog15
Brandon
Covington, Ky
2025 Base 4-Door
Thought about doing something like this. If I was out of warranty it would be no question to do this but I would rather have a dealership do it for now just so it get's an appropriate fix (hopefully).
Jer-E-Miah
jeremiah
Littleton, CO
2018 F150
The bolt on top goes into a clip that rattles too. I put some rubber tape right above the clip and used a larger washer on the bolt. It seems much better.
Ford Bronco Subwoofer housing cracked… IMG_7206
Ford Bronco Subwoofer housing cracked… IMG_7207
B-Dog15
B-Dog15
Brandon
Covington, Ky
2025 Base 4-Door
Thanks for the tip!
Jer-E-Miah
jeremiah
Littleton, CO
2018 F150
Thanks for the tip!
That is a thicker rubber tape than electrical tape. I also put some of the thicker rubber tape between the green connector and the Sub housing. Seems another point of possible rattle.
Ford Bronco Subwoofer housing cracked… IMG_7237
I just wrapped my entire Bronco in 10 mil tape to prevent rattles, seems to be working ok.
Ford Bronco Subwoofer housing cracked… Untitled
Valhalla
Valhalla
Chattanooga Tn
The sub enclosure sounds much better wrapped in a dampening like Kilmat. I cut foam rubber for the bolts.
