Steering wheel binding while turning stationary
Mjolnir
Cash
Georgia
2022 Ford Bronco
Anybody ever have any issue with the steering wheel binding while turning at slow speeds while parking or stationary? For about 2 weeks now, I’ll either be stopped and tried to turn all the way and the steering “hits” or stops and then lets me turn all the way. Feels like it’s briefly catching. It’ll seemingly do it once or so turning either direction. It doesn’t seem to be at any particular point in the turn or consistently do it the same every time. It’s on a 2022 Big Bend non-sas with 3.73 ratio.
Valhalla
Valhalla
Chattanooga Tn
Check the steering link near the driver coil, do you wheel? I'd check the rack also.
Oldhippie
Barry
Santa Cruz, Calif.
Yes it happens and is not safe…probably the rack…get it fixed!
Nc211
Washington DC
Go to the search function and look up this phrase: Steering resistance inconsistent
I can’t figure out how to copy the link myself here. The thread started in 2022. Read through it, around post 30ish you’ll see photos of the steering knuckle. Check yours to it, hit it with WD to clean it up, then perhaps some extra lubrication as well….
Ducati1098
Steering shaft*
Here is the link:
https://www.bronco6g.com/forum/threads/steering-resistance-inconsistent.55975/page-3#post-2541680
CalvinT
Calvin
Phoenix, AZ
Generally it's not a good idea to turn your steering wheel while stationary unless you're on a loose surface.
stevenstommyboy1
Thomas
Menasha Wisconsin
2023 Bronco Raptor
If your moving slowly yes if your sitting still on hard surface no. But it should not bind like you mention. CHeck according to that thread. Fords used to have recalls in the old days for this stuff especially Towncars and Crown Vic’s and Mercs. Corrosion issues.
CalvinT
Calvin
Phoenix, AZ
Moving slowly is OK, even 1 mph.
I agree, it should not bind under any situation.
Valhalla
Valhalla
Chattanooga Tn
well, hard up against a rut with rocks all around...
helifino16
Ron
Mount Sinai, NY (Long Island)
I suppose it can't hurt to say make sure you don't have any 4WD modes active. That will aggravate the steering at slow speeds as well.
Alcotune
St. Philip’s, NL
Ford Ranger
I just had my steering shaft replaced. Not covered under standard warranty.
i was towing a snowmobile trailer when i first noticed it on the highway and I could barely turn.
Seems to be more and more having this issue so hopefully there will be a recall in the near future.
For me it’s the last straw for the poor quality of these broncos. My new toyota should be delivered in June.
