Second failed transfer case
Kickit
Kickit
Sorry to hear this happened again. I'm reaching for straws, but do you think that snow/ice is accumulating against the transfer case and the skid plate causing abnormal temperature variances? I have no idea. Hope you get fixed up soon. Push for the extension on the warranty.
I did have this thought but it wasn’t cold enough to cause that, at least I don’t think. Also, I’m pretty sure the bash plays cover the transfer case? Am I wrong?
Dorf2point0
Richard
Anchorage, Alaska
2022 Explorer, 2005 Explorer, 2013 Escape
20k miles at the first failure, just reached 37k miles at the second. I have asked them to change the diff fluid and they brushed me off, said it wasn’t due yet. I’d change it myself if I was at all mechanically inclined……I am not
I would like you to go through this post.. Bottom line is especially front differential and transfer case fluids need to changed regularly.
thanks to @CarbonSteel
https://www.bronco6g.com/forum/threads/change-driveline-fluids-early.83929/post-2108566
Kickit
Kickit
Felix808
SRV CA
Sorry for your trouble & hope they get you fixed before too long.
Here is some good info for those following the thread 🤠 .
Kickit
Kickit
Also super helpful. Thank you 🙏🏻
I wish the dealer would listen when I asked them to check the fluids. Looks like I’m about to have to crawl up under there myself and learn a few things
Felix808
SRV CA
These transfer cases are fairly simple & it should become clear what is wrong once you take the back 1/2 of the case off.
Good luck. 🤠
Edit: Where in CA are you located?
K76Husker
Shawn
Wichita
2019 Ford F150
Damn that sucks, at least I got mine out to the wild before it failed, for better or worse. Since yours is manual do you not have the advanced 4x4?
side note, since the rental already smells like a dirty sock just fart all over it to really stick it to the man
Yeah it does have advanced 4x4. And I will take your advice with the rental lol
Kickit
Kickit
These transfer cases are fairly simple & it should be come clear what is wrong once you take the back 1/2 of the case off.
Good luck. 🤠
NorCal-Sacramento area
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
Sorry for the long wait, I was trying to find a good enough screenshot of the transfer case and the associated skid plate. The bash plate that you are referring to is not the same.
Ford Bronco Second failed transfer case 1705450208182
Felix808
SRV CA
Hi im here! What did I miss? Im in NorCal/Sac area
Your mechanic skills have been volunteered :p Hey you could do a video so it's a content opportunity 🤠
