Steve_In_29
St Johns, Arizona
2024 Heritage Limited, 2 Door, 1973 Bronco, 1999 Ranger, 2007 F350
Well done.
The only true Ford SAS-spec tire on the list is the 52-pound Goodyear Territory.
All other tires in this size range are significantly heavier. In terms of wheel-end weight, fuel economy and ride quality, Ford engineers knew what they were doing when they spec'd the 52-pound Goodyear tire. It simply works.....virtual perfection.
For the record, I prefer the appearance of the 2021-2024 Territory MT, over the 2025-on Territory RT.
Until it doesn't
Owners report the sidewalls are easily cut on the trail.
Ford spec'ed it for ride quality and MPG, not hard core trails.
Deleted member 72780
Guest
I find it on of the more bare minimum OEM tires out there. I can live with it on my 45k base sasquatch but seeing it on 70k truck is not ok, especially with no warranty
Guest
Since I generated some interest, Ill be fair to Nitto and add the M/T trail grappler at the end. Its 78 lbs though so a stretch for daily driving or more emotional than practical buy.
There is another set of likely low cost models I left off. I see no real point as I would save elsewhere.
Ford Bronco Sasquatch Tire Estimator & Comparison Tool 1766858658232-bo
rcl4668
Pacific NW
2019 Mustang Bullitt, 2023 Bronco Heritage Edition
Great comparison! I looked at a bunch of the same tires on the list and went with the General Grabber A/TX in 315/70/17. Relatively lightweight, three-peak snow rated and good in the wet with good gravel/snow traction. (This is also the OEM tire on the Black Diamond trim.) The downside is is does not handle thick, wet mud as well as some of the other tires like the Mickey Thompson Baja Boss.
blue reaper
Dennis
Vancouver, BC, Canada
2024 Bronco & 2005 Excursion
Have you considered the Nokian Outpost? These come in 315/70/17, are a reasonable weight of 61.7 lbs, 3PMSF rated, load range F, and have a 60k mile warranty.
I recently bought a set of these for my Excursion and am very happy with them.
Guest
Not considering E or F ply on Bronco in this comparison table
While some may be same tire I am not in position to know this.
Guest
That is fair to add General. I'll add on original table later.
Guest
I updated table a bit more with best Bronco Sasquatch AT tire and Best General Sasquatch AT tire.
Top three use cases wont really change to me, while other might need looks or ice etc.
jrollo7
James
NY
Range Rover Sport
Here is new picker with points budget and new table with Nitto added as MT option. Toyo seems to be top pick unless you dont spend all points. Can not say I disagree. I did not add cost on purpose here. I wont add any more as that is enough top picks from top brands.
FactorGoodyear Territory (Current OEM)Toyo Open Country A/T IIIYokohama Geolandar X-ATBFGoodrich KO3 (May Release)Mickey Thompson Legend EXPMickey Thompson Baja Boss A/TFalken Wildpeak A/T4WGeneral Grabber X3Cooper Discoverer S/T Maxx
StatusAvailableAvailableAvailableWaitlist (Est. May)AvailableAvailableAvailableAvailableAvailable
Size315/70R1735x11.50R17315/70R17315/70R17315/70R1735x12.50R17315/70R1735x12.50R17 (C-Load size)315/70R17
Load RatingC (6-ply)C (6-ply)C (6-ply)C (6-ply)D (8-ply)D (8-ply)C (6-ply)C (6-ply)D (8-ply)
Weight~52 lbs (Lightest)~63 lbs~61 lbs (Ultra Light)~66-68 lbs (Est)~62 lbs~73 lbs~76 lbs (Heaviest)~78 lbs (Very Heavy)~66 lbs
Sidewall2-Ply2-Ply3-Ply (Geo-Shield)3-Ply (CoreGard)2-Ply (High Tensile)3-Ply (PowerPly XD)3-Ply (DURASPEC)3-Ply (Duragen)3-Ply (Armor-Tek3)
Balancing8.5 / 109.5 / 10 (Best)8.5 / 108.5 / 107.5 / 108.0 / 107.5 / 107.5 / 108.0 / 10
Wet Traction9.0 / 109.5 / 10 (Best)8.5 / 109.0 / 108.5 / 109.5 / 10 (Best)9.0 / 108.0 / 108.5 / 10
Winter/Snow7.5 / 109.0 / 10 (3PMSF)8.0 / 109.0 / 10 (3PMSF)8.5 / 10 (3PMSF)9.5 / 10 (Best)9.5 / 10 (Best)7.5 / 10 (M+S Only)8.0 / 10 (M+S, Studdable)
Road Noise6.5 / 10 (Loudest)9.0 / 10 (Quietest)7.5 / 108.5 / 107.0 / 108.5 / 108.5 / 107.0 / 10 (Mud Terrain hum)7.5 / 10 (Hybrid hum)
Ride Comfort9.5 / 1010 / 108.5 / 109.0 / 108.0 / 109.0 / 108.5 / 108.5 / 10 (Soft C-ply flex)8.5 / 10 (Good D-ply balance)
Durability4.0 / 108.0 / 109.0 / 1010 / 108.5 / 109.5 / 1010 / 109.5 / 109.5 / 10
WarrantyNone65,000 Miles45,000 Miles50,000 Miles50,000 Miles50,000 Miles60,000 MilesNoneNone
OVERALL7.3 / 109.2 / 108.8 / 109.1 / 108.4 / 109.1 / 109.0 / 108.2 / 108.6 / 10
Best Use CasePavement Princess / MPG Saver. Best if you prioritize fuel economy and ride comfort above all else and stick to pavement or light gravel.The High-Mileage Commuter. Best for Bronco owners who drive 90% on-road, face a lot of rain, and want a tire that is easy to balance and quiet.The Budget-Conscious Trail Rider. Best for someone who wants a tough 3-ply sidewall for rocks but wants to save money and weight compared to the heavy Mickey Thompsons.The "Do-It-All" Loyalist. Best for the driver who wants the gold-standard look and C-Load comfort but needs newer tech/wear-life than the old KO2.The Classic Overland Build. Best for D-Load stability when carrying moderate weight (overlanding gear) without jumping to a harsh E-Load ride.The Severe Weather Warrior. Best for deep snow, ice, and wet roads where traction is life-or-death, and you don't mind a heavier tire.The Heavy Hauler. Best if you tow a trailer or load your Bronco heavy; its HD durability is unmatched, though it is very heavy for a daily driver.The Dedicated Rock Crawler. Best for a "weekend toy" Bronco that lives in the mud and rocks and rarely sees highway miles.The Gravel Road Explorer. Best for long-distance durability on sharp gravel and dirt roads where puncture resistance (armor-tek3) matters more than snow grip.
CommentBest: Lightest weight (~52 lbs) and very comfortable.
Worst: Weak durability (thin sidewalls) and no treadwear warranty.
Best: Best daily driver (quietest, best wet traction, 65k warranty).
Worst: Weaker 2-ply sidewalls (less rock protection).
Best: Excellent strength-to-weight ratio (tough 3-ply sidewall but only ~61 lbs).
Worst: Louder and harder to balance than the Toyo.
Best: Combines extreme durability (3-ply) with a soft C-load ride.
Worst: Not available yet (must wait until approx. May).
Best: Stronger D-Load (8-ply) rating while staying lightweight.
Worst: Poor road manners (loudest and hardest to balance).
Best: Incredible snow/wet traction & bombproof 3-ply sidewall.
Worst: Heavier and wider than the 315/70R17 C-load options; tricky to balance.
Best: Indestructible (10/10 durability) and best in snow.
Worst: Extremely heavy (~76 lbs), which kills MPG.
Best: True C-load flexibility for rock crawling.Worst: Ironically heavier than most E-loads; will hurt MPG significantly.Best: A perfect "Goldilocks" tire; tougher than a C-load but softer riding than an E-load.Worst: Older tread design; technology is dated compared to the new AT3 XLT.
Link has budget of
https://colab.research.google.com/drive/17BlAgKQUgH4uckZJVPYRHXli2_FVj9pj?usp=sharing
The Daily Driver Winner: Toyo Open Country A/T III
The "Aggressive All-Rounder" Winner: Mickey Thompson Baja Boss A/T
The "Goldilocks" Winner: BFGoodrich KO3
A lot of this is subjective and some will destroy all tires and others will all get 60K. Ice and Mud are so subjective and driver dependant I stay away as I want to keep my truck in one piece.
Really great information. Thank youđźš—đźš—đźš—
Steve_In_29
St Johns, Arizona
You might consider adding recommended tire pressure to the chart. As one that calls for 80psi isn't going to ride (or perform off road) as well as another that only needs 50 or even just 35.
RedBeard-421
Dj
Kentucky
23 bronco
Well, for what it’s worth my Bronco isn’t a Sasquatch. But I do have 2” lift on it. I’ve been riding on the Kenda klever RT 35x10.5x17 load range D. 40k miles on them and they never left me stranded. Finally replacing them with falken atw4 35x11.5x17. Curious to see how they do for me down in red river gorge, ky! Lots of neat info In here. Thanks guys.
Ford Bronco Sasquatch Tire Estimator & Comparison Tool IMG_4266
Guest
I considered it but don't want to get involved with that because it is one of the most misunderstood parts of tires. It might be first reason people have bumpy prematurely worn tires.
Tires show MAX pressure like e rated tire might show 80 and ride like a wagon wheel. If you did this on on Fallen e rated tire on bronco you lose traction
Thin OEM good year on light bronco is 39 but too much for maybe an e load rated tire. Pressure is by truck weight not tire number.
Overlanders loaded up will be different than me in 2 door with just my old smelly dog....
