Badassbronco
Georgia
I have never been comfortable with spacers. I feel it puts to much on bearings etc. looks good but just isn’t for me.
It definitely will put some more stress on the wheel bearings. Thats why I didn’t go with anything too extreme in hopes that I’m not putting as much stress. I guess time will tell.
Does any hear a lot of truck and Jeep owners replacing wheel bearings?
Just curious. There are a ton of Jeeps I see daily with much more extreme offsets than me.
tongsun3717
X3
BigHoof
PA
Ram 2500
Like the look but they would be illegal in PA and not pass inspection if the tire is poking beyond the flare.
rtazz17
Rob
Connecticut
2022 Ford bronco big bend
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
Wheel bearings rarely go bad on Jeeps, they are about the best out of all of them...all go bad eventually (say 100k-150k miles). GM products are the most common. It seems like every GM vehicle I work on has at least one noisy wheel bearing. Ford has historically been somewhere in between, but of course it's too soon to tell how Bronco will do. If Ford researched what Jeep did to get reliable hub bearings, then they will be fine.
M4Madness
Indiana
F-150 FX4
...make room to clear larger tires/wider tires.
Sometimes. Other times, moving wheels outward causes rubbing that wasn't present before.
Badassbronco
Georgia
Badassbronco
Georgia
I may go with 37s one day so I wanted to stay around the 0mm offset since most things I’ve read said that is the sweet spot for 37s
M4Madness
Indiana
F-150 FX4
And it certainly may be. I'm sure you've done your research. :)
Bmadda
Wisconsin USA
I have the 37s on mine, and ya, it's about right. You will still need to trim crash bar mount, front frame body mount, and there's some plastic fillers inside the rear of the wheelhouse you might need to remove
TMP
Somewhere, Va.
2011 Super Duty 6.7
Ya……the stock position throws enough rocks as is……with them out that much further you going to be touching up way more rock chips…..
gryphon1231
dj
Miami FL
na
That's also why aftermarket suspension manufactures have requirements for wheel backspacing/offset.
Also a good reason not to just do thing for looks!
