Rubbing
ourcure
kevin
lincoln
24 Bronco
just installed the front mud flaps from Mabett. its a Black Dimond with a 2 inch lift and running 315 (35) tires. have rubbing before full lock ( turning for parking ) any suggestions?
bronco504a
Ahmed
oman
bronco
I had this issue, just stuck it with black silicone :cwl: , i think now if the silicon got damaged the plastic is pulled back due to it being stuck there for months and it should be ok
Cmptn845
Henderson
16 pilot, 16 frontier, 10 maxima
Stock BD? Now running 35's?
Could be the crash bars. They are removed for SAS package.
WarthogJr
'21 Bronco Black Diamond
Remove the mud flaps? Don’t turn the wheel to full lock? Get smaller tires? Embrace the rubbing?
ourcure
ourcure
kevin
lincoln
24 Bronco
removed all that extra safety stuff on day one
ourcure
ourcure
kevin
lincoln
24 Bronco
I'm new to the Bronco thing. parts manager for a Ford/ Chrysler dealership. always had wranglers.
ourcure
ourcure
kevin
lincoln
24 Bronco
I personally hate mud flaps. but it fills the door handles with mud/snow
coadr
Coady
Denver, CO
2022 Ford Bronco Badlands
My AT4Ws rub on the mounting screws for my RokBlokz, but only when the wheels are turned and the suspension compresses
Tofudude
Chan
22 Brono Base Mansquatch
adding a bit of caster should help a bit. Truck would still rub a bit until I had a 1 inch lift installed.
HoosierDaddy
__ Eric
Looks like aftermarket wheels with a ton of poke????
... yep, that's what will happen if you do that.
Having the wheel stick that far out makes that big ol' tire swing in a massive arc compared to the stock offset wheels.
+30 or 35mm offset should work.
(factory Squatch is +30mm ) I run/ran the Methods with +35 with zero lift, 35x11.5-17 Toyos. Ford mudflaps are not an issue with this set up.
+55 might give a bit of rub on the sway bar. (All the other factory wheels are +55mm , including the Badlands on 33's )
HoosierDaddy
__ Eric
Also, thread title had me hoping for a bit more action. :wink:
Similar threads
