Removing back window on a hardtop
MilesD
MilesD
Wisconsin
2023 Bronco
In full transparency, My wife's Subaru has to sit outside when the roof is off, it's a price I'm willing to pay.😅
This is my two car (deep) garage.
Our two vehicles sit outside 24/7… 365 days a year.
The garage is for storage and my work shop.
Ford Bronco Removing back window on a hardtop IMG_7204
MilesD
MilesD
Wisconsin
2023 Bronco
I've taken the glass out many times as I swap it back and forth with my custom half cab...its easier w 2 people, but only takes a few minutes.
How did you remove the wiring leading to the wiper mechanism?? I see no easy disconnect at all.
BigMeatsBronco
Allan
2021 FE 2 door
I recall the plug behind behind the upper trim panel on the rear upper inner portion of the roof. I think it just pops off...the plug has about 1 foot of wire from where it slides into the window Chanel on the drivers side.
MilesD
MilesD
Wisconsin
2023 Bronco
Yes, I found it after a short search.
Ford Bronco Removing back window on a hardtop IMG_7216
…however, don’t allow this to happen when disconnecting the rear defrost
Ford Bronco Removing back window on a hardtop IMG_7217
CitrusBronco
Everglades
Citrus county, FL
Everglades
I kept my mouth shut to not jinx you. It happened anyway, those break off so easy I figured this would happen when you tried to unplug it.
MilesD
MilesD
Wisconsin
2023 Bronco
I may not reconnect it… since January of 2024, I haven’t used the defrost yet and I live in southeastern Wisconsin.
now, if I can disconnect the other without screwing up
24GTBadlands
IL
24 Badlands v6, 24 S650 with PP GT
Now that you mention this, I work is SE wisconsin and I think I have only turned it on for fog.
Jakob1972
Everglades
Steven
Spring Branch, TX
2025 Trax 2RS, 2022 Camaro, 2022 Silverado, 2004 Fummins F250, 2008 Chevy Cobalt
Everglades
If only there was a way to make that rear window roll down and be part of the tailgate. Then we wouldn’t have to futz with it. I know defrost would be an issues but they could put a little electric heater with a small fan for that.
24GTBadlands
IL
All of my mom’s Station Wagons… yes the OG type family hauler, all of them had roll down glass in the back with defrosters, so it can be done.. 77 to like the late 80’s
MilesD
MilesD
Wisconsin
2023 Bronco
I believe the original Toyota Forerunner had an electric roll down rear window and the tailgate operated in two different positions, down and swung open like a door.
very cool.
Jakob1972
Everglades
Steven
Spring Branch, TX
Everglades
My Wife when we first met her car was a 74? chevy station wagon, the glass would rollup into the roof and the tailgate would open down and it rolled under the car even.
The only problem she had with that thing is when she would drive it around, airplanes were always try to land on the thing. that sucker was huge. she always called it the tank, I called it the Lexington.
Dxo
Edward
Maryland
2025 Bronco Big Bend
I have the four-door door cart and it is absolutely amazing. My next thing from them is probably going to be the tube doors. I’m a huge fan of their products as well.
24GTBadlands
IL
I ordered the cart yesterday. As I was a postal carrier for like 6 years, I'm used to having no door. doesn't calm the wife though but she's getting used to it. In the summer the only time I closed the door on the Mail cart was rain. it was kinda one of the best parts of the job.
