Question on what trim to start with
junkjon0814
Jon
2024 bronco sport outer banks
I am looking to buy a bronco to start building on. I am considering both used and new but was wondering is there a good trim level to start with for a build? I like the idea of a Badlands with the Sasquatch package, but also as the Sasquatch is available on others is there one better than the other in reality don’t want tons of fancy luxury add on just want to build a reliable fun wheeler.
KillerPenz
North East
Start with a Base. I don't know what can be done to a Base on a 2026, but still good place to start.
I got a BaseSquatch back in 2021 when you could get the V6 in it. I've seen plenty of people liking the 2.3l though, and my kid has a '24 Big Bend with the 2.3l. The normal 3.73 gears and it turns his 35's without issues.
I'm like you, I don't need fancy shit. That's why I went Base. I'm fine with the convex/concave (whichever it is) mirrors.
CalvinT
Calvin
Phoenix, AZ
You can start with a Badlands and add on, but only if you're willing to keep most of the factory equipment. Otherwise you're wasting your money.
If you're the type that doesn't like factory equipment just out of principle, buy a base and add on.
MNBigfoot
MN
Adding Sas to a Badlands is gerenally a waste of money, especially if getting the manual transmission.
A couple might argue different, they are wrong.
It generally costs more to add stuff after the fact than to get it from the factory - so I would consider that. Especially lockers.
The only things that really haven't been commonly added/changed afterward has been switching between the part time and full time transfer cases, the auto and manual trans, and the 2.3 vs 2.7
Deleted member 74291
Guest
If you go used my rec is a Black Diamond. 4.46 gearing rear locker, vinyl wash out floor, steel bumpers, an aux switches. Front axle locking diff can be added easier on this trim as badlands auto uses 4.46 on non sas. If lockers/gearing isn’t important and you want to build, go base unless you need dual climate control.
Dr Dan
Dan
New York
24 Bronco
My two cents, if it's even worth that, is that the Sasquatch package is worth it. It comes with upgraded differentials, which are beneficial for offroading, if that's your goal.
michelle227
michelle
North Texas/South Canada
Badlands 2dr 7spd/ Mercury Grand Marquis/ Jaguar X-Type/ Fiat Spider
Look at prior year Order Guides as models have been decontented through the years.
Real axle ratio can be anywhere from 3.73 to 4.70 depending on model. On my 2dr Badlands, the 7sp manual got me 4.70 without SAS. I added the electronic front disconnect.
If the upfitter switches are important, model matters on new orders. In the beginning, I believe they could even be had with the Base either as part of SAS or as stand-alone option.
Much of what you want will depend on your intentions and checkbook balance. Some NEEDS can be obtained by careful selection...
GnormalGnome
ee
PNW
2025 Ford Bronco
What is your end goal?
What do you mean by 'build'?
All Broncos are very capable off road, but your needs will vary depending on what type of trails/obstacles you aim for. Balance that with how much work you want to do vs. already having some of the most desirable upgrades.
Badlands is the best equipped non-sasquatch trim. Call it the 'already built' trim. Incredibly capable out of the box with dual lockers. No add-ons needed to take on moderately difficult trails. Mostly just limited due to the smaller non-sas tires.
Any other trim w/ sasquatch added gets you the dual lockers and larger tires, so potentially a step up from BL non-sas.
If no frills or luxury items is also the goal, base w/ sas checks that box. Drop the sas package if you really want to do the work yourself, but your wallet will thank you later if you just get sas now.
DALOLA
Retired
Ohio šŸ‡ŗšŸ‡ø
'24 Mach-E, '22 Maverick, Hot Rods
Just based on your own your limited info, I would go with a BaseSquatch in your choice of doors & color, and build from there. If you want more Lux stuff, jump trims until you get a better starting point. 🤠
Oldhippie
Barry
Santa Cruz, Calif.
BMW X1, ā€˜1928 model A, ā€œ23 Bronco
Everyone has different needs/wants…if you are going for a street ride don’t waste money on Sasquatch…if ya want to do some actual off roading the Sasquatch is a valuable option….if ya are really serious about a 4x4 bronco the Sasquatch package is a waste of money because you will be replacing all of it with better/stronger options…off road capability is the same for all Sasquatch trims (sway bar disconnect on badlands) and later years have better suspension and steering rack….good luck!
HalfmuleFarmer
Thomas
2025 Badlands
Don’t worry you won’t be getting ā€œtons of fancy luxuryā€ no matter what trim you buy. šŸ˜Ž
If you want to buy everything after market then go Base. You’ll save $20K, but then you’ll spend that (or more, most likely) on 3rd party upgrades. If you want the most capable machine straight out of the box, go Badlands-Sas.
