question on start/stop
SNOWOLF
Brandie
Maine
2023 Bronco
I set up my Raptor menu for the ASS to be off. It worked for a day and now I have to press the button to shut off the ASS, even though I turned it off on my raptor screen. Am I doing something wrong or is this a common issue?
TX-Dennis
Dennis
Southern LLano Estacado
Bronco, Lincoln
That's normal - at least for the Base and Wildtrak (and every other Ford & Lincoln with ASS that I've driven. I assume it's the same for Raptor.
SNOWOLF
SNOWOLF
Brandie
Maine
2023 Bronco
it's a little different on the raptor menu than the regular broncos. I know I had a wildtrack and a badlands previously.
From reading the manual it says to set all your settings the way you want them and then hit the R button on the steering wheel. It will save all options. It saved everything, and it worked for a day, ASS didn't kick in when stopped and then next day it would shut off when at a light.
I have a superchips programmer, so I may try to shut if off with that. Being a 22' it may or may not work.....we will see.
PA BRaptor
Kevin
Western PA
Ford F350
On mine, once I save the settings it retains them until the vehicle is shut off. At the next start up press the R button twice to change to the saved settings.
Combustion_King
Derek
MA
Yes
So far the only thing that has been constant for my ASS to stay off 100% of the time, was the Ford Tune. tried FORscan, no luck, MY23.
The setting might be related to the GOAT mode your in? stays on in like sport/baja?
Bschurr
NY
^ this!
SNOWOLF
SNOWOLF
Brandie
Maine
2023 Bronco
Thanks! I'm going to try my superchips and see if it will work on this one....it's a 22' like my BB sas was so I might get lucky and shut it off. I know my 23' BL sas it wouldn't work.
I'll post up what happens when I get a moment to try it.
