PSA: Stay away from Eibach
Pressurized
Rod
Gilbert, AZ
Gen 6 Bronco - Jeep JKU - Wrangler LJ (sold)
Just getting caught up on this thread... Quite the twist there. Have to agree that the image provided by @DC59 looks damn good. And I also did not connect the powder coated springs thread to this one.
It seems maybe jessquatch has vanished? Or a stealth delete? Anyways....
chris@pandamotorworks
St. Louis
2016 F250, 2013 Ford Focus ST
Interesting. Obviously not y'all that said it. So wondering if I'm getting that wrong, or if the reseller misspoke.
They didnt offer them until the very end of OCT. Been something we all were asking for!
St. Louis
I recently bought Eibach 2.0 from Panda - great deal, great service. They are in the box awaiting installation. From the original post, I thought - WTF did I get into?!! Post Eibach response, I think I'm OK. As for the OP: "Bueller? Bueller?......crickets.........
Thank you for your purchase! Not only will we support our customers but eibach has great service as can be seen here :)
LSW
L
North
'24 Bronco Wildtrak
@DC59 well since you are here now..... any plans to go higher on the wildtrack with Hoss 3.0?
The Eibach pro-lift kit springs work on Hoss 3.0 and give you about a 2” front end lift and 1” rear. I just put the fronts over my 3.0’s. Or are you looking for even more?
Bucking_Will
Will
Irvine
2024 Bronco
The Eibach pro-lift kit springs work on Hoss 3.0 and give you about a 2” front end lift and 1” rear. I just out the fronts over my 3.0’s. Or are you looking for even more?
Yes we all know that as that's what the post is about the 1.8 lift.... I wanted to see if they had plans for more.... I will just ask tomorrow, they are using my car for the HD springs
DC59
Corona, CA
F-250
The HD springs aren't designed to run without a load, they are made to make sure you don't lose height with a load (500lb load). Yes you will gain a little bit of height if you don't have the full 500lbs that we tested with and that's ok, but I wouldn't recommend running them without any load at all.
For the record these were approved and released today so they should be on the shelf hopefully In late January. Pre orders can start now with a direct call to you favorite dealer : )
CatMonkey
Lafayette LA
2023 Bronco, 2012 Shelby GT500, 2021 Shelby GT500
I edited OP's pic because of the dark exposure and other obstacles cluttering the shot. I'm scratching my head about his initial complaint. My Wildtrak had a lot of rear rake, so I was expecting to see some Carolina Squat going on, as opposed to dead nuts level.
Ford Bronco PSA: Stay away from Eibach 1733528049339-qn
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
Subaru Outback ;)
hah, nice. i think i'll stick with the bronco. if a switch happens for me the likely target is an F-150 tremor. the bronco simply does not have nearly enough cargo space for me.
in any case, hoss 2.0 blows at lower speeds. so far my only solution has been to go faster. ill probably stick with my 6100 plans.
