Eibach may need to learn from Bilstein
gbub
Gary
Costa Mesa CA
2002 Ford Ranger FX4, 1969 Fairlane Cobra, 1970 2800CS BMW, 1961 Austin Healey S
I just installed the Eibach 2.0 Pro coilovers on my Badlands. I noticed Eibach does not have the bellows to help protect the shock rod from dust and debris. I hear many complaints about Eibach rear shocks failing but not in the front. The rear shocks tend to be more exposed to dust and debris than the fronts. I am sure Eibach shock rods have a dust wiper but those only last so long and then the oil seal starts to get more wear from it, followed by eventual failure. This is only a suspicion but I feel it is a valid one.
Has anyone ever tried to use a bellows on an Eibach shock?
23OBX2.7
AB Canada
2023 Bronco
Can get ribbed and foam dust boots anywhere cheap as well as shaft wipes Id stick with boots.
half-fast
PA
F150, Bronco (2dr)
Give them a call. I've had excellent interaction with their support staff.
I have black bellows on my rear remote reservoir shocks on my F150.
gbub
gbub
Gary
Costa Mesa CA
After getting everything installed, I am not ready to take the rears apart to install the bellow tubes. Maybe in a few weeks, I will forget how difficult it was and maybe willing to tackle it again.
That is a good idea to call Eibach. They can probably tell me what boots would fit and may have something that would work for me.
Thanks to both of you for the advice.
NC_Oak
2024 4 door 2.3 sasq
their customer support is great and you'll get a human on the phone. If you're just looking for BETTER, a split boot approach would prevent and keep you from removing.
gbub
gbub
Gary
Costa Mesa CA
I quickly got on the Eibach chat to see what would come of that. It was explained that heat dissipation was the reason for not using a boot.
My immediate thought when I realized there was no boot on the Eibach coilover was; would a split boot work, but I doubted there was such a thing. I will look into that.
AccuTune Offroad
2021 Sasquatch 4 Door, Jeep JLUR, Tacoma
RC Bronco
Rob
Kansas
'22 Ford Bronco, '97 Geo Tracker
From my experience with 2 full sets of Eibach Pro Truck 2.0’s. Boots would not have saved them. All 8 of mine died within 20k miles
I’ve posted about this elsewhere on the forum
gbub
gbub
Gary
Costa Mesa CA
These would be a cheap & easy to install option for extra protection. Really only necessary for the rear coilovers, the fronts wont get sand blasted like the rears do.
These only go up to 3.5" diameter. I found another brand that also are called seal savers. They go up to 6" diameter. The rear Eibach 2.0 Pro coilovers are a little over 5.5" diameter. I also contacted Eibach and they are seeing if anything in their racing division has something that will work for me.
AccuTune Offroad
Link I sent is to our own branded coil savers made by SealSaver. I'm not sure where you saw 3.5", but these will wrap around a 3.75" ID coil spring, which is about the biggest you will find on applications like this. Do you know what the diameter of those springs are?
gbub
gbub
Gary
Costa Mesa CA
I mistyped 3.5". I saw 3.75" in your link but I thought that was the OD. My rear springs are about 5.5" OD and taper down to about 4.5 on each end. Fully extended they are about 17" long to the seats and about 14.5" long with vehicle on the ground.
It looks like you rebrand the Seal Saver Pro Series Coil Savers because the descriptions are the same except they state the 3.0 size fits from 5 - 6" OD. If yours are the same thing I will order from you.
I can't find on your website where to specify the size
AccuTune Offroad
The Ride Shocks rear springs are similar in size (tapered, multi-rate), and these will fit on those with about 1.5" or so of velcro engagement.
gbub
gbub
Gary
Costa Mesa CA
How do I specify the size. It looks like I need size 3.0 but your link shows three sizes.
AccuTune Offroad
PM sent
