Eibach springs and bilstein 6100's? Anyone?
SnowBronco
Canada
Just wondering if anyone has done the eibach springs on a set of bilstein 6100's? If you have what clip setting did you have the perch on?
I have the 6100 on badlands springs, this set up has me with more front lean than I'd like... (About 1 3/8" difference with front and back on the highest clip.) Other option was doing like half a lift either on top of the bottom with longer bolts on the front struts. Or just leave it. Lol
I mean it should work, I'm thinking about it.
Thanks
Ford Bronco Eibach springs and bilstein 6100's?  Anyone? 1000002287
JediMcMuffin
Tommy
2021 Bronco Badlands
Interesting approach. Considering Eibach markets spring-only replacements for the ESC-V Bilsteins, I suppose that makes some sense. Just how are these springs different than the OEM Bilsteins?
SnowBronco
SnowBronco
Canada
They are lift springs I guess. People use em to level and a couple inches lift. Which would mean to me that I could place the 6100's on the lowest position for a more plush ride (less preload) and still get a lift/ level out.
Badsquatchman
Brent
Maryland
Jeep GC and motorcycle
I have the Eibach springs on stock Sasquatch shocks. they didn’t give me the full 2.1” as advertised. Ended up adding .25” spacer plate to top of shock and .25” spacer to the bottom and this did the trick. The Eibach springs are progressive (softer at top of travel)
Jms1
Oregon
2022 Badlands
I have done what you are asking. Using this picture as reference as it was the vehicle used. The stance was ~ 1.25" higher in the rear with the clip set in the lowest position. The front, to be level was set at the second from the bottom position. The ride was very good. I reverted back to the OEM springs only because I thought it was a little to much lift for my tire size.
