Antonio
Dearborn, MI
2 Door, Base, Manual
Went to buy (AGAIN !!!!) and it is SOLD OUT for my 2026 3.0 Raptor Bronco. I just got the email about this last night..... @Ford Bronco Mktg @Ford WHY PUT SOMETHING ON SALE WHEN IT IS NEVER EVER IN STOCK?!?!?!
Most sincere apologies. We literally sold out of these the day we launched, got more ready to ship, then the email blast went out, and we sold out again. It took us 48 hours, but we were able to get it sorted on our end. We have plenty in stock, so should be good to go for the rest of the month!
Antonio
Dearborn, MI
May want to reach out to Ford directly, because the people you’re tagging isn’t actually Ford
Disclaimer: I do work for Ford. I created this account/user profile to connect with a user having issues. This is NOT an official Ford profile, and is not constantly monitored. But I am disclosing that I am a Ford employee, but also a Bronco owner.
Best!
SoCalBronco77
2023 Ford Bronco
So I tried to set up an account, but it requires the voucher, which I do not have as it is being sent to dealer for install. So suck fest, I have to pick it up, get voucher and go back for install. Does the voucher come with the package or is that another hoop I have to jump through?
I set up the Ford Racing account without the voucher. I didn't register the ProCal tool beforehand. I gave the dealer the unopened Procal tool box. The voucher was inside the ProCal tool box.
Antonio
Dearborn, MI
Got this email and am wondering what is the "voucher? I got the pro cal tool a while back and the dealer installed, is this different in any way?
The "tool" is the hardware, or the little box and plug. The "voucher" is the code that allows you to download the software/tune off of the Ford servers to upload to your Bronco's computer through the OBDII port. Together they are the "kit".
Ducati1098
Best!
Good to know and thanks for clarifying that.
That aside, @Ford is still definitely not Ford. Although I suppose that could’ve been an employee too, but hasn’t been on here in 4 years
MDrums
Tampa
Bronco Raptor
Hey thanks …I got it ordered today about an hour ago. Excited…thanks!
bendover
BMW M2, Bronco Badlands
It won't hurt the engine. Modern boosted engines are already living at the knock limit.
Procal is demanding a higher load target than the stock calibration, the ECU is going to add advance and boost to hit said load target. Your knock sensor is there to correct for an occasional oopsie not be driven into a -9 degree timing retardation because you don't want to run 91 in the calibration designed for 91.
when you super knock and blow a hole in the piston, the cool part is the Bosch MG1 ECU's actually have a Knock Octane Modifier table that'll snitch to the dealer when they pull adaptives data and see you dumped 87 in the truck and deny your warranty claim.
tcovington
Tom
San Francisco
'16 Ford Focus RS, '25 BadSquatch
Not sure this is accurate. The ECU can definitely handle pulling timing far longer than the occasional oopsie. Knock sensor is an integral part of control strategy for GTDi engines. If this was an actual concern, the ProCal page wouldn't say "premium fuel required for maximum performance."
bendover
unless someone has the bin file for the procal calibration and can prove that whether the KOM directly affects the demanded load and timing values i’d say you’re playing with fire.
FWIW I don’t know anything about tuning on ford platforms, but I have tons of experience in the BMW world and I’ve kept a stock bottom end 700whp 3 liter together for 100k miles.
Antonio
Dearborn, MI
So I will preface all of this with a disclaimer: *I work for Ford, but in Marketing, I am not an engineer. Any statement made here is my own, and I am not an official Ford spokesperson in any way shape or form. None of these statements imply any warranties, promises, or contracts official, written, spoken, or otherwise.
PLEASE only use 91 octane or higher fuel in any vehicle with a Ford Performance Calibration installed.
Why would you buy a $50k+ Bronco, pay an additional $800 to get more performance with a tune made for 91+ octane fuel (93 octane if you have access to it). Then put all of that at risk by trying to run 87 octane fuel?
Again, I am here as a Bronco fan and a Bronco owner. I will only run 93 octane fuel in my own Bronco, that I purchased with my own money. I recently purchased the Calibration kit, and will continue to only run 93 octane fuel.
Speculating how much or how little damage may or may not be done, by running 87 octane fuel is a very risky game. Again I only work in Marketing, but I would be very nervous if I had any issues and took my Bronco back to me dealer with engine trouble after having put the wrong fuel in it, while it had the calibration installed.
In short, if you install the calibration please only run 91+ octane. If you need to run 87 octane, please revert back to the stock tune, to ensure that you do not damage your vehicle.
Best,
tcovington
Tom
San Francisco
Best,
Appreciate the perspective, but I do not believe you should be scared of running 87 octane even on an engine with the Ford Performance Calibration. This is an OEM-warrantied tune. The ECU will be able to handle 87 octane. Agreed that you've likely wasted money on the tune if you're running 87 octane all the time. You paid for the power, you should fuel it so that you get that power.
I say this with the perspective of 15+ years as an engine development engineer, mostly on the controls side. Also several years developing control strategies for a major OEM's racing program.
This tune provides a modest torque improvement when the octane rating allows it. That is all. No OEM is going to release and warranty a control strategy that fails the engine if someone goes WOT on 87 pump gas.
philoh
2026 Ford Bronco Heritage
From some of my reading, this helps with the little delay when accelerating from a full stop? Is it worth it?
Mike G
N. AL, USA
2022 F-150 Lightning, 2023(J1) Mach-E GT-PE, '24 Bronco HEL 2Dr
This just came through on my fb feed, I was just about to post the same thing.
Now to find a dealer to do my in flash so I can keep my warranty...
Register the ProCal device using YOUR email and password before you give it to the tech to do the update...otherwise if you let your dealership tech do everything on the setup of the tuner...you won't be able to update your ProCal tuner box later, since it will be in the dealer techs name...ask me how I know.
MDrums
Tampa
Bronco Raptor
So I ordered ProCal on Tuesday from Ford Performance with dealer pick up and install. I also have my ford performance website account too. I see the "Pro Cal" drop down menu and click that and it asks for a validation code. I am guessing you get that when the Pro Cal unit arrives to download the ProCal tune on and upload onto the Braptor. So when I go to the dealer for install I need to give them my Ford Performance website log in so they can enter the validation code, correct? 3 local dealers have never heard of this so I and they am really confused.
