MrGreen55
Kyle
Oregon
toyota scion xb
screw it can't beat the price :whistle:
Ford Bronco 25% Discount on Ford Accessories - Code: GIFT25 Capture9
mattymik
Matt
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
You get a ProCal4, and a voucher code for the tune itself.
The ProCal4 is just a basic programming device. You can change the gear ratios, tire size, and of course you can use it to program the tune profile to the Bronco's powertrain control module. You can also use it to read diagnostic codes, but that's pretty much it. The tune itself is downloaded off of Ford's servers using the voucher code. In order to download the tune onto your ProCal4, you must first upload your factory configuration to Ford's servers using the ProCal software that runs on Windows machines.
Labor is not included when you buy the kit. You can install it yourself if you wish, but if you want to guarantee compatibility with your factory warranty it has to be installed by an ASE-certified technician. Most dealerships seem to be charging 1-2 hours of labor to do the install. The actual price varies widely depending on the labor rates in your area. My gut tells me the average is around the $250 mark, but it really does vary widely.
Cool. Thanks so much!
Marauder
Josh
St Louis
This e-mail was misleading.
Ford Bronco 25% Discount on Ford Accessories - Code: GIFT25 IMG_5314
It only gave me $250 or approximately 9% if I tried to buy the twill retractable top.
Marauder
Josh
St Louis
Unfortunately, you can use either gift25 code or rewards points, but not both. Don't know why Ford does this for rewards points.
You can, but you have to use an even number AND you need to input the number manually then select the ‘REDEEM’ button to apply the number
GroovyGeek
Boyan
'23 Bronco BD
The keyless entry pad is available in accessories. Absolutely worth $120 IMO. After relocating it to the gast tank door it no longer sullies the exterior lines and is super useful at the beach or on a hike.
Razorback
Bill
Dallas
Lincoln MKX
So……. Whatcha got Bubba doing to it down there? Portals? Rack? Or the total package? :cool:
Total package. Portals, rack, ties, 4 link rear, anti sway, 38's. It's like waiting for the Bronco built email. 😂
Arokcrwlr
Kraig
US - Alabama
2014 F150, 2014 Focus, 1973 Bronco
Picked up a set of FP painted CV axles... Not bad for $400ish
telenerd
Laramie
Subaru
Might just be me, but I got all excited for the 25% off but after looking at their parts not much I really want or need. 😕
Callelk
Larry
Idaho
Escalade ESV, Cherokee 2-Door
Going to CA next month so I ordered the wheel locks.........
Karl_in_Chicago
Karl_in_Chicago
Karl
Chicago
Wow, that was quick. Ordered the tow hitch + wiring kit with install for both yesterday and just got the call from my local dealer. Dropping it off tomorrow for install.
vrtical
Doug AI
GSMNP, TN
Fords
cross shopping a bunch of stuff on the FP side.
illverado
Cory
700whp stick shift 2000 silverado 23 basesquatch 2dr 7mt
Code works for the functional beadlock rings and can use the rest of my points. Thanks
Ggerobb
Gordon
Bennett, co
94 jeep grand cherokee laredo, 2022 bronco BD
I used the last discount they sent me. Still have not received my cameras. Not very satisfied with fords order fulfillment process.
mjp2
NJ
2021 Cyber Yellorange Bronco Badlands
Just used it to buy a trailer brake controller for a nice discount 😃
