permanently disable 30 minute idle timeout
mrjking2000
Justin
Loveland, CO
2022 Bronco BadSasquatch, 2019 F-250 PowerStroker
just curious if "police idle" permanently shuts off the 30 minute max idle? often times when out on offroad recoveries, we're doing heavy winching. This puts a strain on your battery. I know you can just go in and toggle it off for that "session" per say, but it auto enables next restart.
if I want to leave the bronco idle all day, I want to leave it idle all day.
I think there is some confusion between "secure idle" which is already on, and "police idle." There isn't really any good info on that.
Does anyone know if this police idle mode allows the vehicle to idle longer than 30 minutes regardless if the idle timeout is on or not? Certainly a first responder somewhere is running a newer ford with this max idle timeout disabled.
thanks!
mrjking2000
mrjking2000
Justin
Loveland, CO
There is a “30 Min Idle” setting/feature toggle within sync, does that not do what you are asking?
that turns back on with every engine restart. but yes, it disables the timeout. i'd like to shut it off forever.
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
I always wondered if police left their vehicle running with the keys in the vehicle or had a "remote start" keeping it going...
vzqhsg
MI
F-150, Badlands
thanks!
Is police idle a selection on the Bronco, or a Forescan change?
Ducati1098
thanks!
Police idle is not for push button start vehicles.
Ford Bronco permanently disable 30 minute idle timeout B90C30CC-DD21-43DB-A3D6-D4E02060B1DF
matteooshe
New York
2022 Bronco
We leave em running all day if we are in them. The newer fusions and explorers can not be driven away or even change gears even if it’s on and unlocked without the key in it. Goes into a Police Safe Mode. Can’t even lower a window if the doors open. Older fusions, explorers and impalas will stay on without the key in the ignition only if your lights are on stage 3 aka all the lights on so you can leave it on and have the turn key on you. Never buy a used police car as it most likely runs almost 24 hours a day.
da_jokker
Jeep Wrangler JKUR
Wait, what?
I knew about auto start stop, but you're saying that the Bronco won't idle for more than 30 minutes without turning itself off? Wtf!
Ducati1098
Wait, what?
Yep, nothing new really. Ford has had this on multiple cars since around 2018. I can be turned off just like auto start stop, except it’s through the touch screen and not a button.
da_jokker
Jeep Wrangler JKUR
Of all things.... I know this seems superficial, but I'm getting really fed up with all these small little negatives with the Bronco.
I need is 30 minutes even long enough to charge the battery after it starts?
Ducati1098
Had someone not mentioned the feature was even a thing, you never would’ve realized it even had it. Seems ridiculous to get fed up about it or even consider it a “negative”. Also not sure what charging the battery has to do with a 30 min max idle. This feature will never even affect 99% of bronco owners.
JohnnyBronco
Pennsylania
X4
Half the states have laws governing idle time for commercial vehicles. CA probably also restricts vehicles like the Bronco, which then screws tge rest of tge country .... even though not idling is better for environment
710-oil-614
Cal
Columbus, Ohio
2023 Maverick Tremor, 2010 Toyota Tacoma
Letting your vehicle idle really isn't enough to charge your battery (if it was dead and needed a jump).
At least the 2.3 you're look at a 100a alternator that will provide roughly 40a of charge at idle.
I guess to your point - it would take 90+ minutes to charge your battery when a 20 minute drive could do the trick.
mrjking2000
mrjking2000
Justin
Loveland, CO
good to know that "police idle" mode does nothing on a push button vehicle.
and yes, the bronco will shut down after 30 minutes of idling in park. which happened to me over the weekend while offroading. we got stuck behind a truck that was completely blocking the road, and in our attempts to recover it, we burned 90 minutes of time. by then after leaving the hazards on for an hour, (granted with LEDs the battery wasn't dead) but the cab was totally cold, and the engine had cooled off.
like I said, if i want to leave it run, i want to leave it run. without having to toggle a button every time.
if any first responders are running a newer ford and know how to defeat this forever i'd really like to know. maybe it's as simple as wedging something onto the brake pedal to keep it depressed...
mrjking2000
mrjking2000
Justin
Loveland, CO
it's in forscan in the BCM. but apparently does nothing on push button rigs.
