OnBoard / OutBoard Air?
Mikem1025
San Antonio
2023 Bronco
Has anyone seen or done the AGS Air Gate mixed with a rear bumper tire carrier? Trying to avoid air under the hood or somewhere inside.
Bilal23
Jersey City
I have been thinking through similar issues. Having a portable unit takes up too much space and the rear-mounted options all seem pretty second rate. (The small air units are underpowered and the big ones e.g. Milwaukee are bulky for irregular off road use). So the best option seems to be under the hood. And for that the ARB seems to be the only game in town, though it seems way overpriced and overpowered for a Bronco that has already has diffs and doesn’t need air lockers.
Bilal23
Jersey City
Meant to ask, what’s your thinking on wanting to avoid air under the hood?
Mikem1025
Mikem1025
San Antonio
2023 Bronco
I guess it kind of depends on whether or not you have to have the hood open when using it? If you wire it up to an outfitter switch, I guess that could work. But then you would need to have a spot to hook up the hose. It just seems easier to have it on the back.
JAD67428
Steven
Just South of Boston,MA.
2024 Ford Bronco Big Bend with Sasquatch Package. 1994 Mustang G.T. 2023 Harley
There is this one I saw but for the life of me can’t figure out who it’s from,
Ford Bronco OnBoard / OutBoard Air? IMG_5307
popo_patty
Caleb
Sacramento
Honestly I’ve been running an ARB under the hood for 3 years now and zero issues. No maintenance at all. You never run it with the hood closed and it’s built to handle the temps of the engine bay. It’s actually designed around engine bays for install.
I wouldn’t put any compressor in the engine bay. But no complaints with my ARB single. I’ve taken temp readings on the single and double and both stayed around 200-250 degrees
Mjasi3
Chicago
AGS
I installed it on my Bronco.
I really like it!
I really like this setup. Was it a pita to run the power cables... especially though the hinge side of the tailgate, I installed my twin under the hood, with kr brackets
RoverDude
Maryland
2021 Bronco (First Edition)
It was a small task. Not a huge ordeal/problem.
I used the supplied molex connector, But I repined it for larger gauge wire. (Bought different Molex terminals)
I ran (2)#8's for power and 16's for control (via aux switch)
Used a circuit Beaker versus supplied fuses.
I also got their air filter relocation it.
Overall, I think it good as works great and it not in the way of anything and barely visible.
I would recommend it, solid built quality.
Ford Bronco OnBoard / OutBoard Air? Battery
Ford Bronco OnBoard / OutBoard Air? CB
Ford Bronco OnBoard / OutBoard Air? Hing
Ford Bronco OnBoard / OutBoard Air? Siz
Ford Bronco OnBoard / OutBoard Air? rear
mcinfantry
Lee
Louisiana
Badlands 2 door
I’ve blown the fuse on mine, hood closed….
Mjasi3
Chicago
Very nice! Thanks for sharing.
