MTB/SUP onboard air recommendations
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
I'd like to add onboard air, but mainly for airing up our inflatable paddle boards and bike tires. I really don't plan to need 4 wheel air up in 5 minutes like most want.
Ideally I'll have the air hose at the rear of the Bronco.
Any recommendations for a budget onboard option for this use?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
You could go with the ARB Compressor and our KR Off-Road Mount. With a single compressor the kit is $587.99 - https://www.4x4truckleds.com/kr-off-road-arb-compressor-engine-bay-mount-for-2021-ford-bronco/
Another option, go with a ViAIR Portable Kit: https://www.4x4truckleds.com/viair-400p-portable-compressor-12v/
They start at $239.95 - You can upgrade it to the automatic version (so you don't have to turn it off between tire fills as you move from tire to tire) and then it's $299.95 - https://www.4x4truckleds.com/viair-400p-automatic-portable-compressor-12v/
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
Thanks! I'll check out the options.
marjen
CT
Looking for something similar and would love to mount a compressor somewhere. And wondering where to get fittings that work with tubeless mtb tires? And SUP fittings.
AlexInNY
Alex
Shelter Island
BMW 428; Grand Wagoneer; MB 230E; Pacifica
I went a little nuts and mounted a 15lb liquid co2 Powertank, mostly because I’m airing up an inflatable sailboat and topping up a RIB. Happy with my choice though it’s hard to find a place to refill the tank around New York City.
