Not sitting level after King shocks installed
Kevin W
usa
AMB 4dr Sasq Base and an Erup Green 2dr Sasq Base
I have it cranked down where the top spring is fully compressed. I will definitely need a heavier spring. Waiting on a recommendation from King.
Dang!!! Put 37’s on that Beotch!!!!! The 35’s look small in this pic!!!!
TX21BRONC
TX21BRONC
Allen, TX
Jeep Grand Cherokee Summit Hemi, Range Rover Sport
Like this? Ha!
Ford Bronco Not sitting level after King shocks installed 3FD0B93C-EC2A-4959-8A79-5EEB8EDFE58C
CASM920
Gen 1 Raptor, Bronco Badlands
4dr Badlands here, Kings with fronts set with 0 added preload and the rear is set from the factory, looks like 2” of added preload. It’s sitting slightly nose high (1/2”) and this is with nothing in the back “stock”. Hopefully I’ll get around to adjusting the rears.
For those with Kings how do your front CV angles look? Inner driver seems pretty steep to me.
Ford Bronco Not sitting level after King shocks installed 00104348-5459-419A-984D-A058B5858E88
Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
Have you put many miles on them yet? It took a couple of weeks of driving, but mine settled enough that I ending up adjusting the front preload about 4 full rotations to level it out.
CASM920
Good point, I have no more than 100-150 miles on them. I suppose I should just drive it for a few hundred miles and put it through its paces before adjusting the rears.
Aztec1382
Sam
F350
The rears will need adjustment regardless. I had to replace the lower spring and might change out the top tender as well
the fronts might, depends not the weight you have on that bumper
Johnny Rebel
LA
I should probably mention that mine is a 2-Door and I have a winch on the front, so that could be why it settled so much. I haven’t touched the rear springs, but it may be different with a 4-Door.
I put at least 1000 miles on them before I adjusted anything.
Cysquatch
Adam
Rancho Cordova, CA
2016 CTS, 1996 Silverado 4X4
Ordered Kings for my 2-door BaseSquatch. Have the fronts in-hand. Waiting on the rears. Am I gonna regret this? I too was this close to buying the ICON billet UCAs until heard they don’t clear. I have Zone UCAs currently. Wondering if that will clear the kings. Might have to got the @popo_patty route and go Icon tubular or RPGs.
Evolkidbell
Northern Colorado
1966 Bronco, 2013 F-150
Take a measurement of the amount of thread showing (preload) and double check with King that the lower spring has enough travel. Really don't want to go solid on the lower spring.
TX21BRONC
TX21BRONC
Allen, TX
I have already upgraded the spring and the preload is not set at about 1" and I am sitting somewhat level (See Pic Above). I will be changing to a heavier tender spring soon to keep it from being so compressed.
popo_patty
Caleb
Sacramento
I can attest that my SPC UCA's and Kings clear just fine. I'm running 37's and have to run spacers until I get 0 offset wheels as the Resi's are quite large and dont have enough hose to relocate. Where King wants them doesn't clear the 37's. Everything else is great as far as clearancing.
TX21BRONC
TX21BRONC
Allen, TX
I have the RPG UCA's and have had not clearance issues. I have -12 offset wheels and KM3 37's. I don't have any rubbing on anything. The resi hose is very, very close to the inside of the UCA's however.
Ford Bronco Not sitting level after King shocks installed IMG_7815
Ford Bronco Not sitting level after King shocks installed DSC01780
popo_patty
Caleb
Sacramento
Took another photo today in the light. The fronts have settled a touch but the angle is still about as much as I can’t stand on the lowest setting. I have more room to go lower in the fender well as I jumped it and the tire didn’t come close to touching the fender.
The rear is going to need a touch more preload as the sagging is real with gear in the back. Whole thing rides very stiff still. I let PSI out of the tires to 28 but the steering became very heavy, I inflated back up to 38 PSI and then the ride was extremely rough. I’m currently at 34 and it’s not great but it’s a compromise. Going to add a touch more caster on Tuesday to see if that helps my loose steering
Also adding a rear trackbar adjustable if it arrives in time from Metalcloak and see if that helps as well.
I currently have the compression to 3 clicks from max soft out of 30 total clicks and it’s still a brick if that gives you an idea how stiff it is haha.
Ford Bronco Not sitting level after King shocks installed 5489721C-5807-4672-BF49-C46F03C57A78
Ford Bronco Not sitting level after King shocks installed 82158582-5B1C-4915-8F19-9968B15203A9
TX21BRONC
TX21BRONC
Allen, TX
Installing the 600lb top spring today. Will update when complete.
Ford Bronco Not sitting level after King shocks installed A873755B-FB4C-4BE5-9312-65A34673ED0A
Aztec1382
Sam
F350
You should stiffen up the rear using the adjusters
i had mine really soft and after a while
I started bottoming out.
