Los
Disco3
Hello boyzzzz, and girlzzzz,
my 22 WT came with the Fox suspension (struts and shocks), So far, I really like the way my Bronco handles on and off the road. can't complain. going on 8500 miles so far. however it all comes down as how stream you want your bronco to be. I guess is one of those things, like my bronco is better than yours or is it "I want my bronco to be the best badddd assss out on the road"
just an observation and a comment, no more. :cool:✌ KEEP ON BRONCKING
AccuTune Offroad
AccuTune Offroad
2021 Sasquatch 4 Door, Jeep JLUR, Tacoma
Are they aftermarket Fox shocks or a Fox upgrade package from factory?
AccuTune Offroad
AccuTune Offroad
AccuTune Offroad
AccuTune Offroad
Canyon Coolers
Flagstaff
canyoncoolers.com
73 Bronco, Dodge 2500, Sprinter Van
Like you I have HOSS 3.0 , same mileage, and love the FOx 2.5's even after really putting them through their paces, but............the hidden winch dipped the front end and I beat the shit out of the winch in Baja. to were it didnt work.......added the 37's and well now its a slippery slope of kinda needing the lift and wanting all the handling if not more so... and I really want to do it correctly an go faster in Baja next time......
Just ordered some Tuned Kings from Accutune last night.
35tires
'23 Bronco, '21 4Runner
@AccuTune Offroad are you ok with a ton of newbie with a very specific use case but unsure on the "right" shock and suspension setup questions?
I'm so lost. I have money burning a hole and a idea of what I want to do, but I haven't ridden in any vehicles with 2.5 resi shocks and I'm afraid I'll drop 5k and hate them.
Chritaka
DFW, Texas
'23 WildTrak; '06 Whippl'd Mustang (sold4upgrades)
I have the EXACT same dilemma w/HOSS 3.0 and wrestling between Fox, Kings and ADS... Tune or no tune, though with purchasing ADS they will make the adjustments per my weight without extra charges....but they're more $$ too. Trying to lift for 37s is just going to make things even worse. It's super plush right now on the road, bottoms out in the rear without much effort. Anything more and it will be like floating around in an old caddy! I haven't even tried to take it through any rough stuff after adding the bumpers/weight due to this...
Chritaka
DFW, Texas
Hey Guys, nice to see someone take a dive in this subject! We noticed in the write up that on the fox equipped Bronco you have a front aftermarket UCA (which has added caster built in, keeping 0'ed cams mostly in position) and a fixed oem UCA on the King equipped Bronco.. If true, a typical alignment shop would have to max out the lower cams to get in spec. Subsequently this would pull out the in-board cv joint where dimensionally Ford already has these too short, and risk damaging/pulling the CV. You also have aftermarket rear links on the Fox equipped Bronco with what appears to be a Johnny Joint or similar, and "hopefully" adjusted lengths to aim the pinion back to spec. Aftermarket joints rotate and cycle with less resistance than a factory pressed bushing. None of what we are saying is aimed at taking away from the incredible assessment you guys made, but it would be better executed had you compared the shock assemblies on the same vehicle and parts configuration. Fox and King both make industry leading products, we exclusively use only these brands on anything we do, but a shock absorber is just one component of a "suspension system". As a shock tuning company naturally you are going to compare shocks as a stand alone product. As a suspension designer and manufacturer of complete systems, we know the importance of collective assemblies and the impact each variable has on performance and longevity.
So with all this being said, if we install proper aftermarket UCA's, we shouldn't need this additional spacer added to the Kings to limit travel. Correct?
AccuTune Offroad
AccuTune Offroad
SEND IT! Shoot over a private message and we can get things cleared up for ya.
AccuTune Offroad
AccuTune Offroad
FWIW, the image APG is referring to is an image sourced from Kings installation guide. For context in the article, our images didn't use the King reservoir mount, so I opted to use Kings image as a reference. In both cases when we installed and tuned Kings, they both had aftermarket UCA, not stock. Both cases had CV bind at full droop.
jbandc122
Joshua
Washington
Bronco Wildtrak, Porsche Cayenne Diesel
I have the EXACT same dilemma and wrestling between Fox, Kings and ADS... Tune or no tune, though with purchasing ADS they will make the adjustments per my weight without extra charges....but they're more $$ too. Trying to lift for 37s is just going to make things even worse. It's super plush right now on the road, bottoms out in the rear without much effort. Anything more and it will be like floating around in an old caddy! I haven't even tried to take it through any rough stuff after adding the bumpers/weight due to this...
For a vehicle like this, no matter the brand go with a tune. I’d take a $2000 set of tuned shocks over any $5000 set of untuned shocks on a Bronco.
As mentioned, Accutune also tunes their shocks free when you buy from them.
Sloth
SWFL
2022 Bronco
What are the maintenance intervals like on the Fox and Kings? Is one easier to service? Is one cheaper to service? Which is considered more reliable?
