Noise behind the speedometer.
JC2DR
Joseph
Maine
Bronco Base 2dr 2.3 7speed
This only happens at speeds over 50 but I get this weird noise like wires banging around just behind the speedometer. Might not be the actual source, but it’s annoying. Sounds like a squirrel is back there messing around.
(I checked, there’s no wildlife of any kind there). Anyone else experiencing this?
PWillette
Parrie
Maine
Nothing here. Does it matter what gear you are in? Just wondering if it is associated with the 7mt 5th and 6th gear syncro grinding issues.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good morning! If you send over a DM with your VIN and Ford dealer info, I can look into your concerns on my end.
JC2DR
JC2DR
Joseph
Maine
It’s not that noise. That was fixed and thankfully working just fine. This is more like a wire banging around. @Derecho mentioned the speedometer cable but only in cold weather. Could be but I noticed this a few weeks ago, wasn’t cold.
PWillette
Parrie
Maine
Strange. I haven't had any issues. So we actually have a speedo cable? I assumed everything was electronic.
Off topic...I see you are in Maine, who did your tranny fix? Mine is getting worse now that cold weather is here.
I thought that was where they keep the gerbils
JC2DR
JC2DR
Joseph
Maine
I am in Rockland Maine. KEY Ford of Rockland fixed it. Took a bit, not because they couldn’t do it right or that they didn’t get the parts for the fix. They did. What took a bit of time was getting g the parts that were not specified in the fix that they needed. That popped up a few times and extended a week to 4. Still though it’s working fine.
JC2DR
JC2DR
Joseph
Maine
I would add, that since I was their guinea pig for this repair that if you went there, they could do it fairly quickly.
BigHoof
PA
Ram 2500
Any chance that maybe it is some sort of hood flutter in the left rear corner?
JC2DR
JC2DR
Joseph
Maine
I thought that as well at first, but it’s right behind the speedometer. The hoods’ not moving at the hinge.
JC2DR
JC2DR
Joseph
Maine
I guessed. 😁
OuterJersey
Honda, Toyota,VW, Lexus, Triumph, Honda MC
I noticed a very slight noise too in that area. I was going to check the speakers I changed out up there
