Weird noise from behind the pedals.
NateDogg1776
Nate
Indiana
Ford Bronco
I just got my Bronco this week and while I was driving I noticed a sound coming from behind my pedal area. The best way I could describe it the sound sounded like a radiation detector. The noise was not constant and stopped when I wasn’t driving. I checked for something being loose like plastic. There still is basically nothing in it so nothing was rattling that I had in there like change or something. Me nor any of my buddies had ever heard something like this. Anyone have an idea of what it might be?
Salt Shaker
Garry
22 Bronco, 15 Jeep GC, 15 Ram 2500
Did one of your buddies put a zip tie on your drive shaft?
NateDogg1776
NateDogg1776
Nate
Indiana
Ford Bronco
LOL, no they did not plus the sound will go for a little then stop then start again. So sadly it could not be that.
Southside_Ray
Ray
Iowa
2014 Ford Fusion
So I actually have had that exact noise the two times Ive engaged the rear lockers. Also had it in 4L if that helps.
NateDogg1776
NateDogg1776
Nate
Indiana
Ford Bronco
Interesting, this was in 2 wheel on normal mode no lockers engaged. Very odd
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello! Could you privately message us with your VIN and the name and location of your Ford dealer so I can look into this noise concern for you? Thank you!
KABQ
Aaron
Albuquerque, NM
I've heard it a few times as well. I believe it has to do with either traction control or stability control, because when it happens I basically lose all response from the gas pedal.
StoicAF
Kyle
texas
2022 Bronco
Any update??
2door
AA
2022 Bronco® The Sasquatch™ 2-door
I hear the same noise when I make sharp turns. I have the Sas suspension and stock 35's. I didn't find any rubbing marks in the wheel well.
Hot Pepper Diamond
Justin
Knoxville, TN
Bronco Black Diamond 4 door
Did you figure this out? I’ve got the same exact noise and it’s driving me crazy….
CalvinT
Calvin
Phoenix, AZ
Does the noise change with speed? Or does it sound the same at 40 mph and 60 mph?
Hot Pepper Diamond
Justin
Knoxville, TN
so mine seems to be caused by airflow… once I get up to 50+ miles an hour, typically on the interstate it starts… it does seem to die off at around 80. Also it seems to happen more if I’m driving straight on or veering to the left… when I veer to the right, it seems to die off.
VirginiaHeritage
Frank
‘25 Bronco HE
Lloyd S.
Lloyd
Massillon Oh
23 Ford Bronco
Any update on this? Mine does the same thing after getting it back from dealer after a cam phaser replacement. Drives me crazy.
