Weird chime noise on opening door
MDH
Southern California
2017 mazda6
I can’t be the only one this has happened to. When my car is parked unlocked in my garage or my driveway and I open the driver’s side door, I get a weird scratchy chime twice (coming from the engine compartment). Not a healthy sound. Video/audio attached. I couldn’t replicate it at the dealer and so I’m guessing it may have to do something with the bronco internet connectivity to my house Wi-Fi. I would love to hear if you’ve had this and resolved it. Thanks.
TXBronco1313
It’s normal. I don’t know what it is exactly but I highly doubt it has anything to do with WIFI
MDH
MDH
Southern California
2017 mazda6
I would be shocked (maybe not 100% shocked) if that’s normal. It’s like the sound of technology dying. Yeah, the Wi-Fi connectivity thing is a stretch, it just doesn’t make sense that it happens every single time in my garage, but not outside of it.
MDH
MDH
Southern California
2017 mazda6
Found another thread where Ford chimed in (pun intended) back when they monitored this forum. They said it’s not normal. So the search continues
myrealname123
Trent
Monterey, CA
'25 Bronco Badlands
Hard to hear exactly, but it sounds the same as what mine has been doing since day one. Opening the door signals the Bronco is probably about to be started, so I assume it's fuel pump priming?
Dan-O
Dan
Fountain Hills, AZ
Normal for mine too…….been doing it since I bought it. I always assumed it was some kind of fuel prime or coolant system. Pretty sure it’s not associated with connectivity.
  • Like
Reactions: TLO
Hopeless Diamond
JR
Chumstick, WA
F350/2dr Rubicon/'96 4R/'02 Silverado 1500/'22 Badlands
I have found that I hit my knee on the light switch, turning them on when I get in. As soon as I start it, it returns to Auto. Took me a while to figure out what was happening
MDH
MDH
Southern California
2017 mazda6
It's completely normal. It's the electronic throttle. If you turn the ignition on, but don't start the engine, you can duplicate the sound by pressing the gas pedal.
Thanks! I will check that.
UncleBrad
Brad
Indiana
2024 Bronco 2-DR Manual
My Bronco has been doing exactly that from the day I first drove it home. It does sound like a dying transducer. I haven't noticed that it was coming from under the hood - will investigate.
KJSnider
KJ
MN
2023 Bronco Badlands 2D 2.7
+1 here also since day 1.
UncleBrad
Brad
Indiana
I can confirm that i8iridium is right: it's related to the throttle. I can duplicate the process as described.
wjtinfwb
Bill
Destin FL
Jeep GC, Excursion, Focus ST, Subaru Crosstrek
Sounds like one of the many relays under the hood triggered by the door handle pull. My '23 BB Sas makes them as well. Really creepy when you go in a dark garage at midnight and your Bornco "talks" to you because of the proximity sensors.
