Mods are eating up my payload capacity
Ophthovet
Stroppe
Mario
Arkansas
2Door Bronco, BMW X6, Newell 45
Stroppe
How do I increase payload capacity on my Bronco with all of my mods? I have a stock 2023 Wildtrak.
I have a front bumper and winch plus rear bumper and tire carrier that will weigh almost 400 lbs! It doesn’t seem like I can add anything like a roof rack or RTT without maxing out my payload limit.
I do not do any heavy off-roading just enjoy nature and camping. I know nothing about suspension except what I read on this forum.
What is the right way to carry more weight?
MileHighCitizen
Al
Denver
Bronco 2D 2.7
You said you don’t do any heavy off-roading, so you can go back to the factory front and rear bumpers to get that payload back. No need for upgrading them if you’re just doing some camping.
If you’re set on keeping them for looks, then the right way would be to get a small trailer to tow since you’re taking it easy, it won’t be a hindrance.
JerryC
Memphis
2022 Bronco
Legally, I don't believe there is any way that you can. What's on the door jamb sticker is what is legal.
You can add to some of the weight bearing items like springs, get higher load rated tires, stiffen the frame, etc... but law enforcement is going to go by that sticker that has the factory rating.
I've never seen law enforcement stick a vehicle on a scale unless it was a pickup with the rear end obviously overloaded. Plenty of trailers though.
Most won't consider "installed" equipment payload - you are just at risk of hitting the GVWR limit. That is pretty hefty for a Bronco - 5,500-6,100 lbs depending on your trim level. Curb weight stock is 4,200-4,900, so you have around 1,000 lbs (give or take - depending on ho wmnay people you haul and how much you weight) to play with there. The Badlands and BDs are the chunks there with factory armor plates and steel bumpers.
Steel armor and bumpers are going to be, far and away, the most installed weight you will add. Stuff going on the roof - like racks and sleepers and stuff, those won't be nearly as bad, since they are designed to go up top.
You also can't just necessarily add in the weight of your mods and add that to the sticker curb weight either. Most of those will pull factory equipment off - especially bumpers and the like. If you are worried about it - go get it weighed at a scale.
But I think you'll probably be fine, as long as you aren't hauling a family of 5 from My 600lb Life.
BlueWaffle
Maine, USA
2023 bronco, and a trio of 80s GM's.
Payload is set by government tests and regulation, no real way around it.
Installed equipment absolutely IS payload.. shit.. even the fuel in the gas tank is considered payload..
JerryC
Memphis
2022 Bronco
These are not precise numbers for all Broncos.
Looking at the sticker from our Wildtrack.
GVWR 6140
Max Payload 917
Weight range from Ford for all 2.7l equipped 4dr models, 4,661 - 5,320
Best case 4661 + 917 = 5578
Worst case 5320 + 917 = 6237
It appears that the max payload plus unloaded weight likely to be the GVWR or close to it.
RagnarKon
Ford Bronco, Escape, Focus
There is no way to legally/officially increase the payload capacity.
But as @Brian_B mentioned, the weight of personal vehicles is not something law enforcement typically polices unless something is obviously wrong. Most of their focus is on commercial vehicles 10,000 lbs and up.
It would be irresponsible for any of us to say, "Well this is the correct way to ignore the manufacturer's guidelines". But, from a practical standpoint you can do some suspension upgrades that will help to a point. ARB's Old Man Emu suspension is a good place to start, but they also will recommend you stay within the weight limit because they don't want the liability of you doing silly things. So go forth at your own risk, and if you are way overweight don't drive near me on hills. :wink:
MadMan4BamaNATL
Ray
Atlanta
You really can’t increase your vehicles overall gross weight capacity “legally”, as what’s set by the manufacturer is regulatory.
However, adding a heavier weight bearing suspension can help to carry the weight you do have better. (Old Man Emu shocks and springs for example). You can also upgrade to Lighter and better wheels or rims.
Question to you is, if you don’t do serious off-raoding (subjective statement), why the winch? Sure a Winch comes in handy when camping in remote areas with a tree down, but that’ll be rare unless your exit is blocked, which would be even more rare. Then, why the upgraded bumpers?
Cosmetic crap, usually touted on a forum or YouTube mess can easily confuse those things that are necessary with what just may look nice. Steel sounds great until you see the weight. Aluminum is often a better option on modern vehicles.
Also, try to streamline other gear like that for camping and whatever. Ground tents are lighter and I like them better since keeps the rig from being top heavy and better for gas. Just spray your ground tent with Sawyer Insect Gear spray to keep out critters (permeth -er-something other); this is what I use on my clothes, backpack, socks, boots, tent, whatever. A few little containers of Ammonia keeps both snakes and bears away from camp if you space them out.
Just remember to stay away from racing suspension upgrades such as Fox or KING and go for more Old Man Emu or ICON which are better for carrying heavy overland rig loads. Fewer rebuilds down the line as well.
Let me know if any of the before mentioned doesn’t make sense or needs more clarification.
desibull
Mahesh
Chandler, AZ
BMW 335i
A good topic of discussion for sure. As for me, I am being extremely prescriptive on what mods I am doing with a focus on minimizing "permanent weight". My goal is to carry offroad gear when needed but take it off when I am using my steed as a DD. I see it completely wasteful hauling around an RTT, a bunch of offroading equipment etc. on a daily basis. But then again, I am not going offroading every weekend; maybe once a month.
MadMan4BamaNATL
Ray
Atlanta
I didn’t read the posts before mine, so I just repeated things said by others and most of it is very good information, so there’s some peer confirmation, although not scientific, but screw that, right? :)
Big thing is be careful with drastic changes to the dynamics and drivability of your rig, so a well thought out upgrade cadence is smart. When you put crap on, you’ve also taken other crap off, but new crap tends to be a tad heavier.
Ophthovet
Ophthovet
Stroppe
Mario
Arkansas
Stroppe
Ok now I feel like I asked a dumb question but thanks for the great replies and education. I see what I need to prioritize now and wait until my needs change for the rest.
HotdogThud
mk6 gti, '21 MoarDoor
Reminds me of how someone once referred to curb weight
"Curb weight is the weight of the car, if you take every single thing out including all the fluids, and put it on the curb."
