Upgrading Bronco fuel tank capacity
GiddyUpThatPony
Dodge Ram 2500
This is based on what? Your market experience as a manufacturer? Titan tanks does exactly what you are claiming will never be done. 🙄
Yes. Replacement fuel tanks with greater capacity than OEM have been available for most HD trucks for many years.
MaverickMan
Shane
And non HD aswell. Hell I can get a bigger fuel cell for my 1980 Eagle if i pay for it. I used to work at a company who made tanks, i did pressure testing. Its no big deal.
AcesandEights
Ace!
Oregon
DR650
They do it for diesel. Not for gas. "Gas" tanks are part of the emissions/EVAP system. Call Titan and ask :rolleyes: then be an adult and apologize publicly.
Saxgod
2018 Shelby GT350, 2021 Bronco Badlands
Why would I apologize to a troll?
AcesandEights
Ace!
Oregon
DR650
Because you were wrong, with attitude. Why not just be an adult about it.
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
High clearance bumper with spare and can mounted gate is in my future. I doubt the long term durability of the rear gate to support near 100lbs off road for a couple 100K miles.
Here is a 12-gal tank made by Titan for the Wrangler…
TITAN Trail Trekker II™ Tank for Jeep Wrangler (4040287) - $402.50
https://titanfueltanks.com/products/trail-trekker/titan-trail-trekker-ii-4040287
Ford Bronco Upgrading Bronco fuel tank capacity trail-trekker-2
Ford Bronco Upgrading Bronco fuel tank capacity trail-trekker-2d
It is similar to the AEV Fuel Caddy, but holds another 1.8 gallons of fuel.
Hopefully it will be adapted to the Bronco sometime soon. If so, it could increase the range of your 2D Black Diamond by 71% (12.0/16.9). (y)
AcesandEights
Ace!
Oregon
DR650
That's nice too because you just leave it empty and out of the way 99% of the time.
Raptor911
Raptor911
Broadlands, VA
Agreed! Since 2010 the scab raptor has had a 26 gallon tank while the screw has a 36 gallon tank. Scab owners have been wanting a bigger tank and 10 years later nothing.
No one will make a replacement tank due to liability issues. YES, you can put a fuel cell in the cargo area if you wish BUT a bigger replacement tank will never happen.
Also if you note the position of the OEM tank, it sits between the frame rails in front of the differential .. so very protected in case of a crash. Aftermarket replacements tank will have to crashed tested and that is not going to happen due to $$ and lack of room.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
RBF 1401
Tricia
Tucson
98 Avalon, 95 Dakota
I much prefer the jerry can mount options. Way more versatile.
If my trip involves extra remote miles or needing to run my gas generator, I can bring extra gas cans.
If my trip is setting up basecamp in the desert for a week, then I can bring extra water.
My extra gas to extra water ratio depends on where I'm going, what I'm doing, the weather, and how long I'll be out.
A dedicated Titan gas tank behind my spare can only hold gas, whereas the jerry can mounts behind the spare can hold gas cans or water cans.😇
AcesandEights
Ace!
Oregon
DR650
I cant imagine ever using this unless you are very specifically taking a remote route where no other gas options exist.
Like... how does one get the gas from this into the fuel tank? The simplest options still seem no less time consuming than pulling into a gas station.
It has very little practical use, just like gas cans on the back but, for that one time.... I carried an empty Jerry can for years on my Jeep, and empty Rotopax on the motorcycle. Almost no one will ever need it.
The Titan comes with a siphon to get it into the tank.
dgorsett
colorado
F250, Mustang, Explorer
Looks like there should be room for four Jerry cans on the hood.
Ford Bronco Upgrading Bronco fuel tank capacity 1623015424589
AcesandEights
Ace!
Oregon
DR650
@Saxgod Were you able to confirm what I posted yet? I didn't see the apology and figured I should follow up.
Stampede.Offroad
SD
junk
...Aftermarket replacements tank will have to crashed tested and that is not going to happen ...
I guarantee you people will buy and add things to their vehicles that are not govt approved. Including fuel tanks.
