Master thread of payload capacity. Submit your build specs here!
midwestpilot
Kansas
Equator
So I'm going to put together a spreadsheet of the different builds and associated payloads. We have general specs but I want to get detailed so if you're looking at a specific trim and option spec you can see what others have. All I need is if you're a lucky Bronco owner already, or if you have access to test drives-send me the specific payload numbers that I believe are on the sticker inside the drivers door. With that I'll also need the option package, Engine/Transmission MOD/HD bumper, type of top and any other customizations as detailed as possible.
I'll be working on it the next few days and edit the link in once its passable.
Shanks!
midwestpilot
midwestpilot
Kansas
Equator
4 Door First Edition
Fantastic thank you! Obviously they put payload in there easily for me, but it doesn't specify curb weight anywhere I can see, correct? This should work great though!
AbeFroman
Dan
Chicago
2021 Ford Bronco First Edition
I think that's GVWR in the upper right? 6180 LBS
L8apex
www.instagram.com
'14 Focus ST, '21 Badlands
GVWR - Payload = Vehicle Weight.
