Real-Life MPG Thread - Report your MPG here.
acnp2022
CT
ford
I think you're only supposed to use eco mode at slow cruising speeds with infrequent acceleration. In what scenarios have you been using it?
Yea eco is pretty much useless in all situations I have found. I used it in normal highway driving which apparently it can't handle.
KyleQ
Kyle
Twin Cities, MN
8 Broncos!
Sweet, looks like we'll get similar mileage to my 19' 6.7 PSD crew cab.... :ROFLMAO:
Tech Tim
Tech Tim
Tim
Wet Side of WA
Jeep JKU
Have been running a metric 33 for the last few weeks. Average mileage has dropped some. Didn't change gearing or calibrate speedo yet, so it's not super accurate:
Milestar Patagonia 285/75R16, up from the stock Base model 255/75R16.
Ford Bronco Real-Life MPG Thread - Report your MPG here. 199mpg
Cased
middle
dune buggy
I posted 18 some time back on 91
So 3k later I'm running 87 and still right on 18
Have not reset and most likely wont for the life of the vehicle
Like was said by others eco is useless to me
Rahkmalla
NJ
15 K900
going up 10% tire circumferance means you're actually getting 10% better fuel economy then your vehicle is registering before you re-calibrate. So pretty comparable to what you were getting before tire change.
MorgansRun
Virginia Beach, VA
BMW 330e
What's your city/hwy driving mix? Not sure if it matters that much since the spread is relatively narrow.
Cheshire
Steven
FL
4Dr Bronco BaseSquatch 2.7L
4Dr Base Sasquatch 2.7L - Exactly 17.0 mpg
Most of these were highway miles driven in Normal mode. Sasquatch definitely hurts.
Ford Bronco Real-Life MPG Thread - Report your MPG here. mpg
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
20.5 MPG
3800 miles
4DR Black Diamond (stock)
2.3L MT
93 octane
Mixed average (majority in Sport Mode) - 60% hilly backroads, 25% highway, 10% off-road, 5% city
zombie
New Brunswick, Canada
'21 Bronco '22 Mustang GT PP 06 Viper SRT10
According to my dash readout I'm getting 13.8 liters/100km, which google tells me is 17 MPG. I've only filled up once so I haven't got any calculated stats from fuelly yet :p
2.3 4 door BL w/ manual
SevenT
1970 U15 Sport Edition; 2021 AMB 4 Door Badlands
According to my dash, I am getting a little better than 16 MPG. Factory equipped it was getting 17 MPG. It went down when I went up to 35s from 33s. 4 door Badlands, V6, Auto on whatever dealership put in it. Most likely 87 octane. Base altitude is 6,00 feet. I did not buy this for Miles Per Gallon, I bought it for Smiles Per Gallon.:cool:
Ford Bronco Real-Life MPG Thread - Report your MPG here. MPG
sledboy
2021 Ford Bronco, RZR XP4 Turbo
We have put over 7,000 miles on our Bronco (Badlands with 2.7) and are getting 20.6 mpg.
Ford Bronco Real-Life MPG Thread - Report your MPG here. Bronco MPG
Techun
Pa
BD, 2.7, MIC, 4dr
All eco is going to do is upshift sooner, and dampen throttle response. So if you press the throttle 30% of the way it may give you 20%.
Sport mode would be the opposite. More reluctant to upshift, and if you push the throttle 20% of the way, it will give you 40%.
Sport mode won't make the truck faster, and eco won't make it slower - except for what gear you may be in. Starting from a stop it's going to be identical at WOT.
