abe
Abe
16 F150 XLT 2.7 (sold 😥), 84 Chevy K5, 09 Chevy T
and when someone gets in a wreck caused by their ACC not working right, and their insurance won't cover it, they're pretty screwed, all because they installed this intercooler.
Then, they shouldn't have installed the intercooler. It's on the vehicle owner to understand that aftermarket parts sometimes don't work well with factory systems. Anyway, if a driver isn't alert enough to realize ACC isn't working, they shouldn't be driving.
Jimmiee
Reno, NV
Chevy Silverado
If the ACC RADAR Sensor is blocked for any reason, snow, road debris, or like in my case, relocation to make room for a winch bumper, the Cruise is turned off. You then get a warning message in the middle of the dash, which you must clear with the OK Button. The Grill camera, bumper sensors, and the RADAR sensor make it very difficult to change anything in the front of the vehicle.
vzqhsg
MI
F-150, Badlands
Were you having issues with your trans? Over heating, etc., on trails, pulling trailers?
LABlueBronco
Louisiana
2001 Jeep TJ on 37" SSRs and 2010 Silverado
Read page 2 for the answer to your question.
Aztec1382
Sam
F350
Now have to figure out what winch will fit between the frame horns and the bumper
So far the warn evo10s and the smitty built are at 21 inches wide
badlands is at 23
Ford Bronco Mishimoto High Mount IC Installed 56B9C4E7-C03C-42AE-A316-67485E6158AD
Ford Bronco Mishimoto High Mount IC Installed 471C6A16-8BD6-4109-B7F8-8C25726DD4D9
Ford Bronco Mishimoto High Mount IC Installed 73F85FE8-06D3-4E68-B458-8559F7F66A6E
BigMeatsBronco
Allan
2021 FE 2 door
Aztec1382
Sam
F350
Thanks for the link
BAUS67
redneck
Central PA
I'm running the older model 12K that is 20" wide. First thing I checked to see if it would fit between the bumper pads. I had not realized they upped the width of the new models. You might still be able to "massage" the pads to fit a new model in there it is only a half an inch on each side. Those pads have some room for that. TBH, those pads could use some reinforcement as well once they are "clearanced". Have you seen the DV8 tow video???
Aztec1382
Sam
F350
Ill check that one out as well
Broncobro04
Alex
Phoenix, AZ
2021 2 door Badlands
Wow glad I found this thread. I’m looking to do the exact same project for a hidden winch mount. I was looking at that warn 9.0rc winch but have you found any others that would fit? I was expecting more clearance between the intercooler tubes…
BigMeatsBronco
Allan
2021 FE 2 door
I think that's the narrowest one and likely the same one I'll buy.
Canyon Coolers
Jason
Flagstaff
canyoncoolers.com
2002 C5 Corvette, Dodge RAM 2500, Sprinter Van 2500
I was looking very hard at the Mishimoto high clearance intercooler.
I already have an RC hidden winch with a 12K Badland's winch mounted fairly low and back some, per their design.
I'm not sure how to tell if this will fit with my 2.7L .
