Manual Transmission Fluid Garbage
Brnzbronc
Indianapolis
On the fill, are you going to do the 2.5 quarts or fill up to the bottom of the fill port? I've seen both, same with the Mustang MT82. Full is actually about 1/2" below the port.
I believe the service manual says 4mm from top
Ford Bronco Manual Transmission Fluid Garbage 9442DD35-29AF-4ED0-B29E-059F985AB324
kodiakisland
Arkansas
I’m not looking in mine for the 4mm line. I’ll stop pumping it in when it starts coming out.
Ogre
James
'23 BD 2dr 7MT CG, '18 Indian Chieftain
I'm waiting on parts for the TSB, but I plan on a drain and fill with Amsoil when it's fixed.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I know the service manual states the fluid is “for life” - but, what’s a normal change interval that is loony birds would normally stick to? 25k? 50k? 100k?
Ogre
James
In a lot of things I've seen "lifetime" means 100k. Of normal use. I wouldn't surpass the mileage for the differential fluid changes which is 150k.
kodiakisland
Arkansas
I think more time frame than mileage for a MT. I like to change mine every 4-5 years in a "normal use" vehicle. That's usually 50-60K miles for me.
Bikeric
Tulsa
2022 Badlands LUX on 37's
"Lifetime" in Ford speak is referring to Warranty. Ford couldn't care less when you reach 60,001 miles.
redone17
Cold Spring, NY
I gotta say…that’s some smoooooth shifting. Feels great. It’s such an interesting difference. It feels like I’m rowing plastic gears now…if you know what I mean.
Ogre
James
What temp is it up there? I'm worried about thicker oil in winter. I might go with your solution instead of amsoil with so many having good results.
redone17
Cold Spring, NY
It’s been chilly the past few days. Low 30s in the mornings.
kodiakisland
Arkansas
I want to go one heavier too, but I’m afraid to do that while I still have warranty. Figure I better stick to specs if I have a warranty claim. Usually wouldn’t have crossed my mind, but I think it’s wise to preserve warranty claims for this MT.
Ogre
James
You can say that again 🤣
kodiakisland
Arkansas
Ordered the Redline fluid. Will put it in next week. Then do a roundtrip to Idaho, roundtrip to Florida, and a roundtrip to Montana over the next 6 weeks. Should have an idea after that how it’s doing compared to stock fluid.
kodiakisland
Arkansas
Can't say I've ever seen MT fluid that thin at room temp, but the Redline seemed as thin going back in. Added around 2.8 quarts before it started coming out.
