I imagine it may wear things a bit but couodnt be much if ya got it real smooth like. Unforntunately i only have 1 manual that barely moves unless im winching something. But i always use to shift like that on my cjs(this ones a t5), and a 92 4.0 2wd ranger( quick truck) and it shifted super smooth. Id clutch 1-2 and 2-3 vut beyond that rarely. Its just a harmonous way to drive.Hey it worked, I could turn the hill assist off and it is better without it. The whole car seemed to run better but that may be because the last time I drove it, it was 85 degrees and I still had the snow tires on....
On a side note since you guys solved my hill assist complaint - is shifting without using the clutch bad? I saw something a while back saying it was bad for the transmission and I wondered if that was true? Depending on my mood I'll often shift from 3 to 4 and 4 to 5 without the clutch. I'm not sure how it could damage the transmission.
I had an old fullsize cherokee that I only used the clutch for starting. It was the only car I could actually downshift in without using the clutch.
