M210 Front Axle Swap?
Rick Astley
Up Doug's ass
d
I would just like an explanation as to why Ford programmed it this way.
You engineer for the slowest and stupidest user as that's where your warranty application losses come from. "Average" is a fairly low bar when spread across the few hundred thousand units they will build.
Sage advice from George:
Ford Bronco M210 Front Axle Swap? 0c4
Rocketeer Rick
Rick
Rochester, NY
2013 F150 STX 5.0L, 1999 Mustang Cobra
My thinking is the opposite - how much heat does the solenoid generate given that it's already in a 220° oil bath?
I'm looking at pre-built timer/relays on Amazon to replicate the Ford circuitry. I'm thinking we just need a 60 second delay and then add a resistor in series with a diode to keep it from staying at 12v.
You could be right, as I said, its not my area. That's just what I've been led to believe by people that are closer to it than I am... 🤷‍♂️
Just_Jim
Minnesota
2021 Big Bend
Just thinking out loud here. I really appreciate your insights as you're closer to the design team than I'll likely ever be. Just trying to hive-mind reverse engineer these suckers for everyone to follow.
Like Billy said - I don't want the ECU to be locking out my lockers depending on drive mode. I do lake "Baja" here in MN in the winter and I absolutely want my front diff locked in 4H.
22luxobx
Las Vegas, NV
2018 Ford F-150 SE
im in same boat, I want to understand but not skilled in these terms, so if I with my non sas OBX Advanced 4x4 was to purchase this front locker set up and the M210 axles it would just be simple to plug in and have dealer properly program it to get the front locking diff to work?
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
No, as of right now you can't get one with 4.27 ratio that you have on the OBX. Also you'd be hard pressed to find a dealer will to try reprogramming. You'd also need new hero switches that have the front locker button.
22luxobx
Las Vegas, NV
2018 Ford F-150 SE
but If I switched to Sasquatch 4.7 front and rear it would just be down to finding a dealer to work with and finding the hero switches?
Harles Garage
Harley
2020 Ford Ranger Lariat
@Just_Jim ever get a FAD delete via the software to work? Or still rocking the zip tie temporarily.
My Big Bend w/ open 3.73 gear (and FAD) should be here next week so I hope to do this swap soon as well. I think I follow most of what needs to be done.
Just_Jim
Minnesota
2021 Big Bend
Never got it fixed and my Ford CS email agent went silent after my last message saying I wasted $136 at the dealer for them to not do anything I hadn't already tried. 🙄🤦🏻‍♂️
So the FAD remains hanging by a bolt and some zip ties. Oh well - at least it works.
joss
Toyota Corolla 6MT
Sorry for not reading basically any comment because I'm at work LOL, but basically is there a way to swap out both my base 2D non-sas axles (3.73 gears open diff) for 4.27 gears for the ELD? money isn't an issue, and i don't need front diff to lock, just rear preferred.
edit: sorry if question is dumb
Patrick
21 bronco black diamond
Interesting update. I am at the bronco take over weekend at silver lake sand dune and the Dana spicer bronco was there with the fdu/ fad delete.
They said ford programmed it for them and it worked perfectly. They also said they are waiting on ford to release the program update to start selling.
I know it’s not much but it gives me a bit of hope
Leesnell91
Lee
Chattanooga TN
2022 Bronco Black Diamond Advanced 4x4
@Just_Jim I have a 22 black diamond the advanced 4x4 non FAD with 4.46 gears. I want to upgrade to M210 with 4.46 ratio. What all will I need to do? Is the Ford perf. m210 (4.46) direct Bolt on?
Rivers90
Ben
Southern California
2 Door Base Sasquatch
You need the M210 drive shaft and M210 half shafts too.
Just_Jim
Minnesota
2021 Big Bend
I ended up just going with 12v constant.
Me and the Mrs. are going to a ORV park tomorrow, so that'll be the first real test. I did hear the solenoids trigger when the windows were down, but we have a commercial deep freezer out there and the fan destroys the audio on videos.
kodiakisland
Arkansas
I'm still waiting for that early 2022 release of the D44 with 5.13s with FAD delete. Probably be waiting a bit longer.
