Lower Control Arm Cam Alignment Pins
Wildtrak'n
Will
Riverside CA
22 Bronco
These are the pins that worked for me, vs the shorter one because the back part of the pin was flat vs the shorter one was domed. After installing these I trimmed them to match the oem lenght.
Ford Bronco Lower Control Arm Cam Alignment Pins IMG_3430
Ford Bronco Lower Control Arm Cam Alignment Pins IMG_3431
Elevator Man
Elevator Man
Dan
2016 Mercedes GLE, 2021 Badlands
Where did you get them from?
kodiakisland
Arkansas
How did you press them in?
NORCALGXP
Sacramento, California
2017 Raptor
@Elevator Man @Wildtrak'n
Excellent thread, need to replace about eight of my cam pins. Just damaged from wheeling. Ordered the SPC's.
Oldhippie
Barry
Santa Cruz, Calif.
NORCALGXP
2017 Raptor
This won’t help finding/replacing pin but may help not bending new ones?
https://bds-suspension.com/products...MIv9mggoWlhgMVRIRaBR3vLwzqEAQYGiABEgJh4PD_BwE
Thank you for the link. I started checking these out and found Zone Offroads with the same thing. Not sure which one I will go with but my camber alignment pins are bent or missing. I like the idea of having two points that hold the cam in place. I wheel hard and each time almost driving home the alignment is way off from the cam moving.
https://zoneoffroad.com/products/fo...nco-cam-lockout-plates?variant=41615233089624
Mdsuits
05 f350, 68 bronco 89 samurai
Still no ford part number for these?
How did these end up working out? 2 out of the 3 reviews on amazon said they fell out right away.
Wildtrak'n
Will
Riverside CA
22 Bronco
no issues at all, they have been on for over 1 year and no signs of falling out
Squatch
removed the lower control arm, used a C clamp and a socket to press them in, no issues
I tried this, because it made sense, and still had to drive them in the last bit with a flat 1/4" punch... which was harder to get an angle with on a couple pins. I used a small 3" C-clamp that didn't give much leverage, though. Maybe a C clamp with a hex head to torque it down?
I imagine the Amazon people didn't press them in correctly or they were using them on a different vehicle. There's no way they'd just fall out after being pressed into our LCA brackets.
Mdsuits
Yeah now that I put them in I see that. They are tight.
JohnGalt
Tahoe, CA
2023 Defender 110
Did those GM pins from SPC work? I just ate a big boulder in the desert and bent a pin. Won’t hold the alignment now.
I see you have Icon Rebound Pros. Mine took a big hit breaking the rim, but the bead held. Drove 60 more trail miles in the heat of day, before changing to the spare that night at camp.
Ford Bronco Lower Control Arm Cam Alignment Pins IMG_3625
NORCALGXP
2017 Raptor
Yes they did just came back from a week in Moab.
NateTTU
Nate
Fort Worth, TX
2025 Bronco
I bought the SPC pins mentioned earlier. They aren't working well for me. I tried a couple different clamps, and even an alignment installation tool. I think they are just slightly too large. I can't get enough leverage on the clamp to press them in fully. When I really crank on them the clamp tends to shift off to one side. Ant other tips? You can even see the clamp starting to bend in the pic below.
Ford Bronco Lower Control Arm Cam Alignment Pins 1776218133542-a3
