Looks vs Logic - Tire size ??
  • Thread starter Deleted member 64921
  • Start date
  • Watchers 33
JEMSA
Phoenix
70 Bronco, 82 F350, 91 MX5, 93 MX5, Bronco
So.......the age old tire size dilemma.......did you go strictly LOOKS or did you choose LOGIC??
For my 2025 Base 7MT -
LOOKS tells me go with 315/70/17 on a +30 offset wheel (FP Everglades)
LOGIC tells me go with a 285/70/17 on a +55 offset wheel (BD steelies)
The 33" tire is LOGICALLY a better tire for a 4.46 geared 2.3 7MT
BUT the 35" tire LOOKS really good and I know I will give up not only MPG but acceleration as well.
What say you ?? 🤔
At the risk of hollering at kids to get off my lawn, I’ve always found it unmanly to follow appearance for appearance’s sake. How did big tires get to look manly? Because we used them to get out to the back pasture to fix a fence. Okay, that led to the creation of off-roading as a pastime. Not so manly, but fun. Putting big tires on because you want appear like you fix fence, off-road when you don’t? It’s not tough, it’s fashion. Same as those who are into stance vehicles. Not so functional but it’s fashion. It doesn’t make much sense for construction trucks. Beds so high need a ladder to reach them. My old dump bed F350 looks tiny at the job site parking lot, but it can haul more, do more work, easier to use then the jacked up cartoons. When I track mud or manure in the cab, I pull the floor plugs and hose it out. Then again, asking for group consensus doesn’t seem particularly manly either. You want big tires on your truck, get big tires. Why would you care what I think?
Oilbrnr
Scottsdale, AZ
'97 factory locked LX450, '16 Power Wagon w/FWC, '25 Bad/Sas/7MT
Since the OP is in FL, one can only assume this is a pure image thing. Go for the big ones!
I'm still shocked at how many people buy "off-road" vehicles in states where there are limited (if any) areas to actually use them off-road. I do 2.5 miles of washboard, airborne capable whoops, loose sandy washes every day just to get to pavement.
not on the rug
NJ
2024 Wildtrak. 2011 BMW X5M. 2024 Nissan Pathfinder Platinum
Anyone that desribes a Bronco as a "Rig" loses all credibility with me. Big tires are way cooler, you're welcome.
This guy used to work at my company years ago and he always referred to his "rig" or "the truck" and my ears always perked up but he never said what he drove and I never really engaged him in conversation. One day we had to carry some items out to "the truck" for an off-site event and as we walked into the lot I was eager to see what he drove. You'll never guess... a Hyundai Tuscon. No lie
EveryDayBronco
Motorcycle
What say you ?? 🤔
Tire weight makes the biggest impact on fuel economy and performance.
Some of your big heavy tires are sucking over 30% of your power just to turn those tires. Put your truck on a dyno, before and after.
dejones64
Dan
MN
Bronco 2-dr Black Diamond
Split the difference. Get 285/75 R17 on the BD steelies. That gives you a 34 (33.9) inch tire with plenty of sidewall but should be less drag than the 315s.
I like the look. Did you get a lift or coil overs? Thanks.
jjack50
Jack
Temple, NH
2013 VW Jetta TDI, 2016 F350 4WD Crew Cab
Looks good! How many inches of lift did you get with the procomps please, did you adjust them or go right out of the box
Did a 2" puck lift.
dejones64
Dan
MN
35x10.5 kendas on procomp coilovers with photo this time.
I would think you'd start running into clearance issues if you lower and go 35s unless you get some insane offset.
Rspayde
North Ga
2022 C/O Black Diamond
I don't recall on either front I'm higher than a factory sasquatch by a bit but don't have exact numbers.
Mattyfly42
Matt
2021 4 door 2.3L MT
so here's my dilemma. I have 7mt badlands with fp tune My ko2s are about done. Thinking I want to go 285/75/17. I have sas takeoff wheels on. Looking for a little beefier look but don't want to sacrifice too much power or mpg. So looking at the Toyo/s they seem to be one of the lighter 34's. How much difference would it really make going uo to a 34? Or should I just upgrade to 285/70 ko3's and keep the power or mpg? I am stuck.
Montana Bronco
Montana
Chevy
Go with 33x12.5r17. Sasquatch width with 33 inch practicality. Looks badass.
Fmuguira
Frank
Idaho
Jeep TJ
IMO a 285-75-17 would be perfect. Nearly 34” tall and still 11” wide. That Turbo 4 (2.3) has plenty of beans for that size a tire.
