Looks vs Logic - Tire size ??
  • Thread starter Deleted member 64921
  • Start date
  • Watchers 33
EasternSierra
Bill
Sacramento metro, California, U.S.A.
2025 Bronco Badlands 4-door 7MT, 2023 Ford Transit Connect van
That makes for problems......wheel speed gens, antilock brakes, etc, etc
And you might just have a little problem with the driveline locking up or breaking in 4WD. :wink:
jjack50
Jack
Temple, NH
2013 VW Jetta TDI, 2016 F350 4WD Crew Cab
Nice !! Looks good‼..... ️AND.....I have a set of like new BD steelies just waiting for tires 👍
It’s a manual too
What tires you running? Those are load D or E ??
That's a problem with that tire size, they are all HEAVY tires
They are KO2 load range E. Makes them about 10lb heavier than the Goodyear Territory 315s Load range C. That’s the trade-off I accepted for the size.
Guest
It’s a manual too
Yikes, that's a lot, thanks for the info 👍
Oldhippie
Barry
Santa Cruz, Calif.
What vehicle would you recommend as a 2 door SUV with a manual, removable top and removable doors for on-road activities?
yeah well ya got me there…I would also like a nice road going convertible suv with power top in my old age…
Greenbronc
Joe
2024 BD manual 4-door
I found some cheap sasquatch take offs. The tires were on their last leg but I wanted the wheels. My original plane was to do 33s, but i liked the look of the 315/70. It also felt much more planted than the stock BD 32s. I found about 1mpg difference in everyday driving. But it seemed to even out overall. I will say the short gearing in 1st is annoying, but thats the same for every Ford manual I've had. 6th is also useless unless above 75-downhill. But 35s look much better IMO.
Ducgsxr
Houston
Warbirds ‘19 scab Raptor, Italian racecars Superbikes, etc
Have a 2Dr 7MT non-SAS Badlands. Personally, I don’t see a huge difference in looks between the 33” and SAS 35”. I went with 4.7 7MT 33” because it’s better at everything, other than some types of wheeling. Significantly less unsprung weight; with all that goes along with that. Handling, CG, accel, decel, ride quality. My wheeling will only occasionally have significant rock crawling, and my shorter wheelbase puts me about even with a Moar door with sas, by my estimation… ymmv
Guest
damn, that rig was $20,000 more than I paid for my 25 Base, want to sell your painted hardtop? 😄 post up a pic here, that's a super nice rig, what brand tires? OEM tires? Thanks
Ducgsxr
Houston
paid $52k otd with some freebies, which I’m happy with on a custom order. OEM tires, ordered this top to avoid MIC issues 👍
DefNotBuddyLee
Austin
Mustang / Jeep / F150
This tells me you are team "logic". In that case go with 33s.
Team "looks" would have said "33s in front and 35s in back...rubber rake like a rat rod?...
Ford Bronco Looks vs Logic - Tire size ?? 1760555961521-
Technicals get worked out after aesthetics. Ask Dodge.
23OBX2.7
AB Canada
2023 Bronco
Power top avail for Bronco 4 Dr....
