- Bob
- Nov 1, 2023
- 25
- 3,538
- 9,274
- Mid South Texas
- ‘15 Mustang ecoboost, 4wd Excursion, ‘69 Mach 1
- Black Diamond
Yes. Exactly like the ARB.Do u know if it can also be mounted under the hood?
I agree. I made my own. By the time you're done walking around, setting it all up, waiting the same amount of time to fill the lines, a single hose is just as effective and easier to keep clean.Don’t waste your time on 4 way hose kits
Four way has the inescapable setup/teardown time cost, though. That's my problem. Do a really good 5psi dual with quick setup and nobody would care about the four, since you spend most of the time setting up/tearing down at that psi.https://www.ebay.com/itm/116486398474
Nothing better for brute power in this price bracket.
And a budget 4-way: https://www.ebay.com/itm/116581413126
Yea this is what I’m worry about too, so much things to considerFour way has the inescapable setup/teardown time cost, though. That's my problem. Do a really good 5psi dual with quick setup and nobody would care about the four, since you spend most of the time setting up/tearing down at that psi.
Honestly I usually just use half of the 4-way myself. A single hose to do 2 tires is pretty easy but still saves time.Four way has the inescapable setup/teardown time cost, though. That's my problem. Do a really good 5psi dual with quick setup and nobody would care about the four, since you spend most of the time setting up/tearing down at that psi.
Oh, I thought you had to worry about the compressor overheating. I've never tried two hoses on a twin.Honestly I usually just use half of the 4-way myself. A single hose to do 2 tires is pretty easy but still saves time.
2 is a little restrictive but not as bad as a single, you'll get 4 37s done without hurting it, just give it a cool down before sharing with your buddies.Oh, I thought you had to worry about the compressor overheating. I've never tried two hoses on a twin.
Interesting, will have to try that. I've only had it get hot maybe 2-3 times (hot to the touch). Usually my MORRFLate TenSix (non-pro) doesn't overheat and gets done for all four tires in 2-3 minutes max. It's just 3-5 minute setup, 2-3m teardown. The time airing up usually feels very secondary by then. The whole thing was close to $500 and honestly, it shouldn't be half that amount.2 is a little restrictive but not as bad as a single, you'll get 4 37s done without hurting it, just give it a cool down before sharing with your buddies.
Yup. Been there. The next day I ordered the 2.5gal Milwaukee compressor (not the tire inflator)You just don't want to spend 90m in a Holiday Inn parking lot at 4am like I did waiting for a Husky "truck" air compressor to get these big tires filled.
no never did an install thread but the Marz video you posted is very good and I still just use the battery clamps for wiring…party on!@Oldhippie did you ever do an install thread? Thanks!
