Looking for budget compressor and inflator&deflator combo
Tofudude
Chan
22 Brono Base Mansquatch
Buddy recommended one of those Chinese clones compressors on amazon. Cutoff switch modded been solid so far. built a 4 way inflator which is cool but its bulky. At some point I will be switching to an ARB compressor and having the truck plumbed with hose fittings at every wheel.
Dejavu
Brett
Fort Mill SC
Bronco, F250
Hello!
recently joined the community and just looking to round out my gears!
my ride is mostly a pavement princess but I usually go on trips a couple times a year.
I know the underhood ARB duo motor is widely loved by the community but I can't justify spending 1k on something that will be used a handful of times a year.
Is there another (preferably underhood) compressor that is more budget friendly (I'm thinking roughly 250 for whole set up) that I should be on the look out for?
I've heard good things about the NAPA maxi trac, trickflate 300, thor's lightning etc, Im looking for something that I can have on the car daily and can use the car's power with no issue, ideally with a auto top feature.
Hoping to find something like the ARB where it's part of the vehicle with easy set up when used. Should I just save up for the ARB? 😓
Additionally, if someone can recommend some inflator tubing to go along with the compressor it would be great! (ideally for both inflate and deflate, but I'm content to use the brass screw on ones as well)
Thanks!
For the tire deflator bit of your question, these work great. Pretty accurate, easy to use.
https://over-sand.com/collections/all
