- Jul 14, 2020
- 125
- 6,166
- 7,052
- California
- Jeep Wrangler JKUR
- Wildtrak
First, credit to @Blksn955.o and his thread https://www.bronco6g.com/forum/thre...or-setup-4-tire-air-up-air-down-system.31208/ for giving me the idea. Just wanted to do a 2nd thread as to not highjack his great idea.
So These Are the Parts you need:
(Amazon Links)
$18 1/4 Air hose 50ft ID 4mm OD 6mm Air tube Blue Polyurethane PU Air Hose Tube Kit with fittings for Air Compressor Fitting & Fluid Transfer
$24 (you need two 2 packs) AstroAI Air Chuck, Heavy Duty Closed Flow Lock On Tire Chuck with Clip for Inflator Gauge
$3 Control Devices - TV12 Brass Tank Valve, 1/8" NPT
(Home Depot)
$4 1/4 in. MIP x 1/8 in. FIP Brass Bushing Fitting (because the hose kit only comes with 3 x 1/4 adapters)
$4 1/8 in. FIP Brass Coupling Fitting (to connect the Schrader Valve to the 1/8 adapter included in the hose kit)
Basically what you are going to be building with those parts is this....
Now it is up to you how you want to do the hose. I want to be able to inflate from the back. So I went from the 2 front tires, to the rear tires. Then from the rear tires to the Schrader Valve so it all sits inside my cargo area.
So in my case...
Front Wheel to Rear Wheel = 12'
Rear Wheel to Valve "Y" = 6'
Small hose sections you see in pics (3 of them) = 6"
I wanted a Schrader Valve so that I can deflate and inflate using whatever means I normally would use on a per tire bases. For example if you have one of those Fancy Air Down screw on things.. it just takes 1 and you do all four tires at once! Of course you could adapt the connector has you wish. However I will say the Schrader valve being 1-way allows me to hook up (or disconnect) all 4 tires without loosing any air.
So I connect the air chucks without any air loss.. then connect my pump to the Valve or Deflator.
AND, just because I know someone will ask, my little pump takes 5-6 min per tire to pump from 20-36. This system, doing them all at once took 23 minutes. So basically whatever pump up\deflator method you currently use per tire stays the same overall. So why do this if it doesn't save you time.. 2 main reasons...
1) Bad weather.... I hook up all 4 at once, then climb back in the rig until the deed it 100% done.
2) TPMS sensors... this method for both inflate\deflate keeps all 4 in Sync.
Happy Off Roading!
(Amazon Links)
(Home Depot)
So in my case...
Happy Off Roading!
