Dewalt Tire Inflator
Boostedblues
Joe
Kentucky
2016 Focus RS, 2011 F-250, 2004 Ranger 2016 Fusion
I got a Milwaukee M18 tire inflator. ive used it on time to air up the 35s on the bronco and it did great. I use it for bicycle tires to truck tires.
Roach011
James
North texas
23 Bronco Wildtrak
I've had a small single piston viar for YEARS. Still have it, but now it lives in my wifes car for emergencies. It worked great but was slower than a bike pump on my 35'' tires. I just recently upgraded to an ARB dual an its night and day. worth the money.
sklnbnzaz
Graham
Phoenix
Bronco, Ranger
We have an ARB Twin... With that said, it is expected that it will be quicker than most. I have seen people with the Cordless (Milwaukee, DeWalt etc..) take a lonnnnggg time and have to stop for breaks midway or run the battery out, we have just helped them get aired up. I have also seen the lower volume entry level Harbor Freight, Viair, Smittybuilt etc... blow hoses or overheat during air up of just 4 35" tires from 20 lbs. It's an expensive investment but if you off-road regularly, then you're going to want to spend the money. For the occasional user, not as big of a deal.
Realtor
chris
chicago
Bronco, GT350
DeWalt should work. I wanted to not get a surprise. Ford Performance kit will work. ARB will work.
Morrflate at $365 was my seldom to use choice. $160 for a compressor and $205 for the hose kit and pressure gauge.
I went where there would not be another option to air up for 60+ miles after airing down. No worries, it worked.
gjptennis
James
Massachusetts
Audi A4, Subaru Outback, 2022 Wildtrak
Thanks everyone, that’s why I asked the question. This is the other system I have been considering, along with their dual compressor
I have the two tire set up from MORRFlate and the ARB twin mounted in the engine bay. was it cheap - not really. but it's efficient and worth it to me so I don't spend too much time airing back up at the end of the day.
duckgumbeaux
Louisiana
2021 F150 Platinum
I own two of these. One for my truck and one at my lake house. They are awesome. You can also plug them into a 120 outlet or use the battery
TrailRaider
Mr. G
So. Cal
Focus ST, Mitsubishi Montero, Bronco Badlands
I have it and used it when I went to the big bear bronco bash. Went from about 22ish to 35 in about 6 minutes per tire, no rest between tires with 1 6AH battery and 1 of 3 bars left. If you only occasionally wheel, it should be fine. If you are out every weekend, it's probably best to get a more robust system.
Hdscreens
Will
2dr Bronco Badlands
I’ve used my dewalt inflator for at least 5 years. It is a bit slow but easy to set pressure and forgot about it as others mentioned. Besides filing tires it’s useful for my other uses such as mountain bike tires, inflatable kayak and inflatable tubes when doing those outdoor activities. Lower capacity battery might be enough to fill 4 tires from 18-36 but will definitely need a charge afterwards. Luckily I have mid capacity batteries that last 3x’s longer each. Much larger size batteries I don’t recall if they fit?
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Tdub0527
Ted
Minneapolis
'21 Bronco Badlands, 2024 Rivian R1S
I also have this Dewalt air compressor. As others have noted it is sloooooow. But if you are a patient person it will definitely fill all four up. It’s never run out of battery on me either.
It’s a good cost effective/multi use option that you for sure should consider.
KABQ
Aaron
Albuquerque, NM
I use one because I already had it. As others have mentioned it will do 4 tires (adding 12-15 psi to each of my 35s) no problem on a single full battery. It's isn't super fast, but it works and I've never had it shut down for over temp, even without rest between tires.
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
I have a compressor installed under the hood and yes, it is an expensive investment, but one that I'd argue is more impactful than, say, wheels and tires which a ton of guys are more than willing to part money for with most to gain in one's own ego more than anything.
I know a guy with a Milwaukee M12 compressor and basically it overheated on him and he only has 33s (only I say, geez).
If you are in 35s and even think you may go run trails on occasion, I'd save up for either an install of at least the ARB single, or get a VAIR that connects to the battery.
It's almost like anything under $250 is emergency use only, which sounds crazy I know.
I do expect my ARB Twin to last at least the next 10-12 years.
Agree 100%. I have twin ARB installed. 45 seconds per tire! I am home while the guys with cheap solutions are still on the 2nd tire.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Got to admit, I want to try and go a little less expensive since I will not be off road a lot. who has used this inflator? Will it handle the load?
These are not designed to air up big tires constantly. It's one of those things you keep for emergencies OR for bicycles and smaller things. I would NOT recommend a small battery operated compressor for a Bronco.
If you want an inexpensive portable kit, check out the UDA Portable Kit. it's $159.99 and will air up a 37x13.50 from 18PSI to 35PSI in 1 minute, 45 seconds. And that's a BIG tire. So it'll do a 35" in about 1 minute 15 seconds or smaller tires quicker.
https://www.4x4truckleds.com/uda-egoi-portable-air-compressor-system-5-6cfm/
4x4TruckLEDs.com
Adam
Lindenhurst, NY
We stock the MORRFlate systems. You hook it up to your air compressor and then you can air up all 4 tires at once. You need a decent compressor though since you are airing 4 tires up at once and you won't want to overload the thing. It'll take 4x as long don't forget since... it's 4 tires.
I like using the MORRFlate with an on-board air system such as an ARB Twin or the UDA EGOI 2. You can also use these with the portable ARB systems:
https://www.4x4truckleds.com/morrflate-quad-4-tires-up-to-125-wheelbase-1/
If you do plan to use this with a portable system you WILL need to buy the adapter that works with whatever portable compressor you have. We sell the adapters as well
