Portable tire inflator recommendations
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
The VIAIR portable compressors are popular. We stock the 400P here.
400P requires you to turn it off in between tires, as there is no built in pressure switch. So if you want to leave it on while going from tire to tire, you can also keep the chuck open (i've used a zip tie in the past)
400P-Automatic will automatically turn off as it has a built in pressure switch. So you can go tire to tire without leaving the chuck open
Available here
400P ($239.95) - https://www.4x4truckleds.com/viair-400p-portable-compressor-12v/
400P-Automatic ($299.95) - https://www.4x4truckleds.com/viair-400p-automatic-portable-compressor-12v/
Ford Bronco Portable tire inflator recommendations 1649539066530
Googz13
Joe
New York
Subaru Forester
Maxitracs are back in stock at Napa.
Chelada
Bulverde, TX
2022 Bronco
