Locker failure question
Area51BS
Ron
Badlands non SAS 4dr 2.3
watched a video of possible failed E-locker which leaves the Bronco as a sitting brick. Is this true? Possible? If so I was thinking about a possible dummy load circuit which could be plugged in, representing itself as a functioning locker and load it presents to the computer. Any first hand experience on a failure?
SierraBronco
Link to the video? If your locker doesn’t actuate your display icon will turn gray instead of orange, but I haven’t heard of it disabling your ability to move.
Hmm.
There is no actual feedback that the locker engaged. There are only two ways the computer would be able to infer it indirectly. (For the record I don’t know if it does this at all)
it could tell if a coil were opened or shorted (improper amps to the coil - just like it can tell if a tail lamp is out)
it could tell if the wheel speed sensors on the axle aren’t both at the same speed when locked
It does seem any time the AWD or ABS detects any fault it locks out all the goat modes and locks out 4Hi (although it seems 4Lo would still work, at least from what I’ve seen)
Bikeric
Tulsa
2022 Badlands LUX on 37's
This is how I could tell my front locker was not engaging, even though the Hero button on top of dash was glowing yellow. It did not "brick" my Bronco, as I was able to continue my trail ride in 4Lo, just knew my locker wasn't going to be there.
Ford Bronco Locker failure question 517466-d884c66a4930e20939c1417263651e00
SierraBronco
An image reflecting my previous response. Thank you sa’ar 🙏🏼🙏🏼
Area51BS
Area51BS
Ron
Latest Matt’s Offroad. The video only planted this in my head. Nothing in the video backed up the possible failure.
SierraBronco
Ah. Literally just watched it. This is why we wheel with a laptop as part of our recovery equipment. We actually reset his computer for him last year when he broke the other side. Losing your locker or axle shaft won’t disable the vehicle, but a difference between the front and rear in say, 4H or 4L, will. When he broke last year I was also underneath it pulling his driveshaft for him. We reset everything on his computer and he limped out in FWD. Everything was fine until his front tires slipped. Computer saw the rear tires weren’t moving, the fronts were, and it threw a “DANGER TO MANIFOLD” error or something that he couldn’t simply tell to shut up (joke) and kicked him out of everything.
There’s a reason I had I think nine different bronco profiles on Forscan before the last time I cleared it out. A laptop with Forscan can save you a lot of hassle.
Bikeric
Tulsa
Yes, only my Expert Driving Skills, Supernatural Reflexes and Superior Trail Acumen, allowed me to conquer the treacherous obstacles unscathed, while un-aided by any front locker, so I could continue on my epic journey back to civilization.
:sunglasses: :crackup::cwl:
userdude
Denton, TX
2023 2dr Badsquatch
Did you ever make it? Back to civilization?
Bikeric
Tulsa
You can find out by reading my epic paperback:
Ford Bronco Locker failure question 4A450D3F-1DF6-4632-BAC1-F7E08D1F0207
I don’t want to give away the ending, but we are all still here, so………
userdude
Denton, TX
2023 2dr Badsquatch
Very nice! Will have to pick that up. What I'm currently reading, it's scintillating!!
Ford Bronco Locker failure question 1760123682388-rv
murphtron
T
Berkeley, CA
2023 Badlands, 2013 Toyota Highlander, 2000 Miata
How do you reset the computer using Forscan? Is this more than just clearing codes? I have not had a need to do that yet. But can understand why carrying a laptop and dongle while wheeling is useful.
SierraBronco
It’s resetting the codes, disconnecting the battery (both posts) and then touching the terminal connections together. Let it sit for 10-15 minutes then hook the battery up and reset codes again. This isn’t any kind of approved sequence created by Ford or anything, but it was the only consistent way to completely reset the codes and computers.
We have forscan lite on our phones but even using the same dongle it just doesn’t work compared to the laptop
