Air locker install questions
Sozzy1269
Southern Idaho
23 Bronco 2door, 2012 Raptor, 2017 f350
I'll be installing an ARB locker in the rear diff, and not sure how othere have mounted the switch for the compressor to engage the locker. Don't really want to cut the dash. Where have people mounted the supplied switch in their broncos? Is it better to get a factory hero switch and adapt it? If this needs to go in another thread, feel free to direct me.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Most people I've seen with air lockers (which admittedly is very few) just use the Aux switches built into the Bronco. But... obviously that's dependent on actually having those switches.
Sozzy1269
Sozzy1269
Southern Idaho
Yeah, I don't have them.
Sozzy1269
Sozzy1269
Southern Idaho
Sozzy1269
Sozzy1269
Southern Idaho
Search for the thread I put together for installing them. If you want them that bad, it can be done.
That's a great mod, but more than I want to bite off at the moment.
Does anyone have any other options? Could I add a hero switch to my base? I currently only have the TCS and flashers on my hero switches.
The locker came with a rocker switch, but I don't really want to cut my dash to use it. Any other ideas for mounting options?
Max1h
Max
www.instagram.com
23 Bronco Badlands, 1968 bronco, 23 bronco badlands number 2
would addin a switch pros setup work? they work just like our AUX switches, if i recall Switch pros makes a harness to make this setup work
Sozzy1269
Sozzy1269
Southern Idaho
I ended up using i 6 gang power unit. Works great.
