- __ Eric
- Mar 6, 2016
- 38
- 6,445
- 16,789
- NW. Indiana
- 68&69 Broncos, 21 AMB Base 2dr 7mt
- Base
Ok, good news, then you don't need to worry about touching the front and down the road IF you do get a bigger tire, you'll most likely be fine gear-wise.I hadn't thought of going past 30s for tyres. I only wanted a rear locker for times when I'm out and get hung up in sand or mud, but I'm not into rock crawling or anything terribly serious. That's one of the reasons I got the base w/o the sas upgrade.
That just leaves the sucky part that you have to mount a new pinion gear because of the welded ring gear/carrier fiasco, the ring and pinion gears are matched sets.
Looks like it might be damn near even cost to re-gear with an ARB vs a whole new Ford replacement E=locker axle. You might be able to get the whole axle housing discounted at various dealers.
Cool thing about the Do It Yourself locker route, you can leave it locked and it stays that way without a computer nanny unlocking it as it sees fit.
It would be REALLY cool if we could get and use the dash mounted HERO switches (or similar) for add-ons like this. Research required on that front.
