Limit Top Gear - Progressive Range Selection - Does it work for you?
Ducati1098
When in M, it still automatically shifts through the other gears and isn't temporary though. I can take a video if you've got any doubts.
It's still completely different. M mode will hold the selected gear as long as it can. It wont be shifting like it is normally in drive.
dgorsett
colorado
F250, Mustang, Explorer
Seems folks are missing the point. At any rate the OM excerpt from @Mr Nick is interesting. It would be great if it worked and was adaptable to older models.
Nibroc99
Corbin
Rochester, MA, USA
www.corbonthecob.com
2022 Wildtrak: The WildeBeast
Gotcha, I've driven in M mode plenty of times like this without issues though driving in the mountains so I guess it comes down to what people are used to.
SHANUT
Craig
Hermann, MO
Had this feature on previous cars and it's very handy for various reason. I can not get it to work on the Bronco.
Has anybody had success with this?
https://www.fordservicecontent.com/...ingEnabled=False&userMarket=usa&buildtype=web
On Ford trucks, you can lock out overdrive gears, which is fantastic to keep from overheating your transmission due to needless shifting on the highway. I can count the number of times on one hand that I’ve driven my F150 in 10th gear. I always lock out at least 10th gear and sometimes ninth gear depending on the terrain. It keeps the transmission nice and cool and the truck still gets over 25 miles per gallon on the highway. And I’m pushing 200,000 miles on the 10 speed with zero issues.
itwelder
Lee
SoCal
BaseSquatch 2DR
Unless I'm reading it wrong (which I probably am), it seems to say that it's for the Raptor.
"Using Progressive Range Selection-Excluding" : Raptor. In other words, it's for Excluding a range of gears, and it's for the Raptor.
Maybe you are reading it like this:
"Using Progressive Range Selection" - Excluding [the] Raptor.
This is one of the first things I tried when I got my new 25, and after it didn't work I had to re-read that title a few times.
Mr Nick
Mr Nick
Nick
Chicagoland
2026 OBX SAS, 1969 Olds Cutlass
itwelder - I do believe you are incorrect. Check these out:
First one is Excluding: Raptor - and the instructions are for non-Raptor Broncos
This one is Raptor and the instructions are for a Bronco Raptor.
itwelder
Lee
SoCal
BaseSquatch 2DR
Ya that makes sense. Dang it now I gotta put another checkmark in the "wrong" column.
Nibroc99
Corbin
Rochester, MA, USA
This doesn't make grammatical sense either, as the use of a colon is to introduce a list or explanation that directly relates to the independent clause that comes directly before the colon. So it's definitely "Excluding: Raptor" which means that it's excluding the raptor.
DALOLA
Retired
Ohio 🇺🇸
'24 Mach-E, '22 Maverick, Hot Rods
I've been bitching about this since day one with the Bronco. Select-Shift works so well in the F-series, and Ford decided to F'up the Bronco... Somebody on the Bronco team needs seriously bitch-slapped.... 🤬 It's annoying as hell, and makes me wish I got the MT...
OP, it does NOT work as described in the Bronco.... The gear hold is temporary, which is stupid as F. 🙄
Nibroc99
Corbin
Rochester, MA, USA
It's temporary unless you switch to M. It does hold indefinitely if you don't touch the gas though. I was going downhill in 6th gear on the highway for a good 10 minutes straight without switching to M (just staying in D and using the - button to select 6th and then idling downhill). Soon as I got back on the gas to go uphill again it took about 10-15 seconds and then upshifted.
mdainsd
2025 Bronco, 1974 Bronco, 1969 Bronco, 2014 Raptor, 2012 MegaRex
I'd settle for "towing mode" like my F350 and Gen1 Raptor have. two taps on the brake and it downshifts and holds that gear until you touch the throttle. Also delays upshifts which is good for the transmission.
Nibroc99
Corbin
Rochester, MA, USA
Oh now THAT would be really nice.
dgorsett
colorado
I use Sport Mode as a defacto Tow Mode, it's close
Motovita
WA/AZ
25 Bronco
Mine works like this, yours doesn't? You just press the minus button while in D, as it says, you have to already be in motion for it to do anything. Say you're going 50 downhill, and you wanna use engine braking, you just press the - button until you're in the desired gear, and it holds until it times out after pressing the gas or until you shift to M and back to D. Or press and hold the + button as it says.
Me too.
