Leaky timing cover 2.3l
HulkBronc88
Clayton
Tampa
2021 Ford Ranger
Good afternoon,
I noticed recently that my timing cover appears to have a slow leak. I cleaned it up my first oil change, and it's definitely leaking. From what I can find, this appears to be relatively common. But I'm concerned about if it's worth taking it into the dealer. I believe they have to reset timing when taking the cover off? I read about someone's engine grenading because a tech didn't set the timing properly after fixing the timing cover seal.
Granted my Bronco is still under warranty, I'm just not a huge fan of dealerships.
Ford Bronco Leaky timing cover 2.3l 20231213_094159
Ducati1098
This is very common on for most Ford 4 cylinders. But personally I would just wait until you're closer to being out of powertrain warranty. They likely wouldn't warranty that small of a seep at this point anyway because Ford considers a warrantable leak something that is actually dripping.
The crankshaft pulley and timing chain sprocket aren't keyed to the crankshaft, so if it's installed incorrectly then it can cause issues, but it's extremely rare for it to be so far off that it would blow up. As long as they use the correct tools to hold the crankshaft where it should be while installing the pulley it's a very easy repair.
HulkBronc88
HulkBronc88
Clayton
Tampa
2021 Ford Ranger
Thanks, that's a good idea to just wait. I know its not a priority repair like cam phasers on the 2.7l etc. I'll just clean it up from time to time until it gets bad.
Rednek
Jimmy
Northern Alberta
I did this repair on mine just before warranty was up,is a very common repair i've done on the 4 and 6cylinder engines (silicon sealant doesn't seem to like extremes in temperature that we get in frozenland)
HulkBronc88
HulkBronc88
Clayton
Tampa
2021 Ford Ranger
Oh the fires of hell here in Florida haha 😄
Mustbeheresomewhere
Micah
2012 Chevrolet Silverado, 2022 Bronco Badlands 4D
I noticed that mine has a slow leak at the timing cover as well. Same spot, near the alternator pulley.
HoosierDaddy
__ Eric
NW. Indiana
Just noticed it on my 2021 2.3 the other day as well... yay.
I can think of worse things ... just had the windshield replaced on the 23 Badlands yesterday.
Hooray! for $0 deductible glass coverage.
HulkBronc88
HulkBronc88
Clayton
Tampa
2021 Ford Ranger
I am having my windshield replaced on Tuesday as well. Second replacement in under a year. Lordy...
Mustbeheresomewhere
Micah
The timing cover on mine still leaks. It’s covered in dirt and spreading and making a mess. I’m thinking of making an appointment at the dealership but before I do. Does anyone know the torque spec for the timing cover bolts? I want to see if they’re just loose.
dgorsett
colorado
F250, Mustang, Explorer
We sure are spoiled with modern engine/drivetrain seals. in the old days if it wasn't loosing a teaspoon aa day no biggy. To me now, no drip no leak.
Ehucek
Evan
Ohio
95 Integra, 00 CRV MT, and 20+ Others
Just noticed it on mine as well, gonna try to check torque if I can find the specs, time to call the dealer.
fpostgate
Farley
Syracuse, NY 13219
Ford Bronco 2024
Glad I'm not crazy, 13,553 miles and timing cover is leaking.
dgorsett
colorado
I sent my dealer this picture and they got me in the next day
Hmm. Mine looks kinda like that, but no drip or drop on the floor so I'm thinking its fine. Maybe I should reconsider.
Ehucek
Evan
Ohio
I dint have a drip either but it’s under warranty and shouldn’t have a leak like that at 11k. Dealer didn’t put up a fight at all.
