Status
Not open for further replies.
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
  • Like
Reactions: Dom
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
Thank you for the summary of your install experience, I have a set of these arriving Monday, and it would sure be nice if I could inspect them for the incorrect upper mount condition that you had, before tearing into the install....Can you elaborate on what was wrong, and what to look for? Thanks! -Rob
Sure thing. I installed the rears first. Those went off without a hitch. When I went to install the fronts, I found that the upper mount stud spacing was off. The studs and OEM holes did not line up. Pictures of OEM and what I was working with from KING. 93mm OEM stud spacing Vs 100mm. Shot KING an email and pics and they sent out replacements.
Ford Bronco KING 2.5 PERFORMANCE SERIES INSTALL AB101226-6AC4-4100-A87B-C9300F62E8C6
Ford Bronco KING 2.5 PERFORMANCE SERIES INSTALL 116D5EE8-3C27-4A69-A096-3E8EFCEB3D90
Rwhite692
Central Valley, California
1972 Blazer, 2022 Wildtrak
Ah, I see. Off just enough to not go in.... I'll be checking mine for sure. Thank you!
1970Budster
Sara
San Dimas, Ca
2021 Ford Bronco 4 Door
Looks Good! 👊
I have the Kings on my Bronco with the Baja Kits suspension and I love it!
AccuTune Offroad
2021 Sasquatch 4 Door, Jeep JLUR, Tacoma
Yep :/ we got a batch with the same. They are Tundra top hats.
Raptor.Tremor.Bronco
Miami, FL
2021 Bronco Wildtrak, 2014 Raptor, 2020 Tremor
How does it feel under braking with the kings? My stock bilstiens feel like they nose dive a ton under just regular braking, drives me nuts
mzmanny
VA
Mazda Miata
What production date tags do you have on your shocks?
Evolkidbell
Northern Colorado
1966 Bronco, 2013 F-150
Looks great!
Also looks like you got the newer "longer" hoses on your front shocks. The set I have were built early on and the hoses are a few inches too short. King sent me some brackets to help fix the issue but they're still really tight. When I have to eventually open them up to rebuild, new hoses are on the list.
Rwhite692
Just received my fronts and checked them, sure enough, they have the wrong upper mounts on them. Thanks again OP for the info, would have sucked big time to discover this after tearing into the install. Fired off an email to King, hopefully they can send me the right ones quickly....(Update: King was super responsive, and is sending out new mounts immediately)
Ford Bronco KING 2.5 PERFORMANCE SERIES INSTALL stud_spacing
popo_patty
Caleb
Sacramento
I also had the wrong top hat on one side. Got I new by the next day from King. Now I have a weird issue of the front sitting over 2" higher then SAS at the lowest possible setting. Me or the shop can't understand why its sitting so high. I want to take out 1/2" but physically can't.
Johnny Rebel
LA
2021 2D Big Bend, 2022 Bronco Raptor
They’ll settle after you drive it a few hundred miles. I don’t remember exactly how much, but I know mine settled quite a bit.
GreyZ
Gulf South Louisiana
Did you retighten your lca and uca bolts after the bronco was sitting back on the ground? or did you tighten them with it in the air.
Pseudoko
Vince
Chino, CA
My 2 Feet
going to pull mine out of the box when I get home from work to check but are front and rears both 93mm spacing?
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
I never measured the rears, since they went right in and I did the rear first. I would think that they're the same stud diameter and spacing.
Status
