fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
The plug and play harness powers the key from the harness that powers the factory radio.
That is what I thought, but on page 64 several people are talking about a $10 power adapter for the kicker key 200.4. That they had clipping at volume 17, then installed that and it would go up to about 22 before it did.
Ft. Worth Rob
Ft. Worth
BMW X7, Bronco OBX
The black end of the $10 harness plugs into the Kicker Key 200.4. The white end plugs into the plug & play harness that runs to the radio. This leaves you with the raw black ground wire to ground to a place on the body of the Bronco, the red power wire to run to the battery with a 20 Amp fuse inline within 18” of the battery and the blue remote turn on wire that isn’t needed because the speaker level audio inputs provide enough signal to turn on the amp. If you don’t use the $10 power adapter, the power and ground are fed to the Kicker from the radio. I can’t speak to the clipping issue as I used the power adapter, not radio power and ground, and didn’t have that issue.
Ford Bronco Kicker Key Amp 200.4 Install DIY Video - Do this first! 4F837840-159E-4A3E-8113-11136368D1A8
Ford Bronco Kicker Key Amp 200.4 Install DIY Video - Do this first! D1DBDA4C-3D71-4095-9D36-FA3046D0777F
mintypickleman
A
2008 f150
Yea I read that too. I haven't had a clipping issue yet but with the key at 15 it's LOUD and I rarely turn it above 12. Although it is undoubtedly a better option for the amp to power it from the battery, at this point I probably won't unless I have those issues when the weather gets warmer and I pull the top off and the volume needs to be higher.
mintypickleman
A
2008 f150
I have been following this thread but honestly I am totally lost and envious of all contributors on this thread and need some direction.
I have a 2 dr mid package. I bought the Mabett pods for the rear so I can put 6.5’s in the back. Do I just need the 200.4 amp with 4 - 6.5’s and a set of 4’s with the plug and play adapter ? I’ve talked with some local shops and they talk about tuning, is that needed? Some say a sub is needed as you lose bass. Do I need a sub? I’m looking for crisp, clear and louder.
Kicker or JL speakers, is one better than another?
Please help with what kit or pieces, I’ve looked at the site but I’m lost in the weeds.
What you have proposed would work great. The amp has the microphone and playing the test tones and running the setup, the amp will tune itself. Most people are pretty happy with the results, some aren't. But the big reason the key amp is so popular (aside from it's small form factor) is because it has the built in dsp and the microphone for easy tuning, without having to really know what you're doing.
As far as bass goes it depends what you want. Even with the 6.5s your just not gonna get much bass no matter what you do, you need a sub to really fill out the low frequencies.
For my install I haven't yet added a sub I'm still deciding if I will in the future. I only upgraded the 4.5s in the dash and rear pods, kept the stock 6.5s in the kick panels, and it's leaps and bounds more crisp clear and loud.
I ran mine in the bi amp setup which I highly recommend, but it would be a waste to run in bi amp and run 6.5s in the rear pods. If you don't bi amp definitely use bass blockers for the dash speakers
fallguy
Tennessee
Awesome, thanks. I was confused at how two plugs, plugged into one plug. Didn't consider one plug went into the other plug, then into the amp. I'll probably try today to get everything in and see if I need to go above 17 or not. Really feel like it should have been included though.
BBSas
Alabama
Thank you for the help!!!
OhhhhhhSnap
Elan
CO
06 Pathfinder, 04 F150, 14 CRV. 22 BD Bronco
Sorry if this has been asked but almost 70 pages is too much to read through.
How is the quality of the speakers/kickers of the Complete Package A? I'm not a big car audio guy so idk much about brands.
https://plugnplaykits.com/collectio...lified-radio-plug-n-play-audio-harnesses-kits
Hopefully they are better than the stock? I'm not looking for anything to blow my socks off but just some sort of improvement on the crappy stock system without breaking the bank.
fallguy
Tennessee
Finished up my install today with the amp. Copied most everyone else, and replaced front with kickers, kick panel with 6.5 kickers, got the Mabbet 6.5 rear pods and put kickers in there too.
After reading this and watching a few videos only took about an hour to get the kicker 200.4 installed. Only hiccup was after putting back together.... nothing worked. I tested it and calibrated the DSP before putting everything back together. Apparently when stuffing the plugs and wires back in, the plug from the head unit barely came unplugged. Plugged it back in and put it all back together.
MUCH better than the crappy stock setup. Thanks to all contributors for making things easy. Next up, I want the kicker tailgate sub. Doesn't look too hard but it'll be a first for me wiring that up.
CrytpX
OC
992S, Badsquatch
Is it worth it to upgrade the rear to 6.5 using the Mabbet using the key 200.4? I feel like it's going to be underpowered.
Ft. Worth Rob
Ft. Worth
BMW X7, Bronco OBX
I’m my opinion, it depends on whether you prefer your music to surround you versus having a front center image that the key’s dsp features provide. If surround I could see doing the 6.5 in the rear.
mattsmeesh
Seattle
Taco
So I'm planning on doing a key install immediately, and then *potentially* adding a powered sub amp in the future. Should I get the plugnplay kit #11 or #11-2 to future proof?
Bearcat1
Travis
2017 Expedition Limited, 2006 BMW 330xi
I would recommend getting the kit with the sub wiring. I started with key only, then quickly decided it needs a sub. Called PlugNPlay and they helped me with the additional cables to add the sub after the fact. Worked well, but would have been much easier just to get it originally.
SlvrSurfRidr
Wilmington, NC
22 Badlands Carbonized Gray 4DR, High/Tow, SoftTop
I did the same, I suggest the 12-1 kit. You'll for sure need a resistor to run the sub, so you could get away with the 11-2; however, the 12-1 comes with the PAC LPA-1.2 which is RCA ready and has some cool features to help make the powered sub a plug and play event.
mattymik
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
Is it just me, or is the 200.4 basically unavailable anywhere?
Has it been this way for a while?
fallguy
Tennessee
Not a huge audiophile, they are much louder than the 4's before them. I can tell a difference. I also wanted 6.5's in the back because I plan to hook them up to an amp when putting in a rear sub, and they will have more power then.
It was for me when looking. Just kept checking around, got lucky and got it from Amazon earlier this month, for $280 I believe.
