VAtruck
Put the gain close to zero - no idea why people crank the gain up when its louder than all hell half way up on the volume dial.
Exactly. Increasing the gain also increases the sensitivity of the radio's volume knob, making it more difficult to fine tune the audio level.
VAtruck
Frankie945 said:
You don’t need forscan if you get the kicker key you can turn the rears up loud as you want with the rear gain on the amp.
This seems counterintuitive. Wouldn't you want to remove the ford dsp via forscan before amplifying the sound? Simply cranking up the gain would likely increase the distortion unless you have a clean/full range of sound that you're sending the amp?
Yes. Removing the Ford equalization will send a true signal to the amp.
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
So 2 years ago I started this adventure... I think I read too fast and didn’t understand everything. I made the EQ change in FORScan, didn’t notice a difference and gave up. Even though I’d bought several items…
Anyway, recently realized my mistake, made a couple more FORScan changes, and now have better sound. Time to install the 200.4 amp! But I don’t have a subwoofer or amp for the back yet. I have what’s in the picture (already installed Kicker speakers in the factory locations) and I don’t remember what my plan was… (what is this LC2i thing??)
Ford Bronco Kicker Key Amp 200.4 Install DIY Video - Do this first! IMG_7270
Think I’ll be able to run everything through the vehicle and it'll work? Or will a lack of sub and amp throw some error and I’ll be soundless until I get a sub/amp?
It’ll be fine.
mikec426
Russellville, AR
I’ve got sound! Not sure all is working correctly… After setup the happy tones never quit until I unplugged the amp. I plugged it back in and all seems well. Did that by any chance just undo all the setup? Also, the power light on the amp never turned off. Is that normal? I wouldn’t think so…
I pressed the Radio Detect button so it’s out. Amp turned off after a minute, but a little pop went through the speakers at the same time.
mikec426
Russellville, AR
Line Output Converter (LOC). It is used to convert the audio signal from the front speakers to the form required by the subwoofer amplifier.
So with that thing, connect the amp to it, run power to the amp, connect a subwoofer and I’m good to go?
VAtruck
NateTTU
Nate
Fort Worth, TX
2025 Bronco
I’m going to be installing the plugnplay kit 19 with the kicker 200.4 and 500.1 amps. I bought the mountains2metal bracket for the 200.4. I’ve not started to tear everything apart yet. Is there also room behind the dash to mount the 500.1 so I’m only running speaker wires back to my sub going into the factory location?
I'm looking at this exact same kit, how do you like it? I already upgraded all the speakers to Alpine S2s, including replacing the rear pods with 6.5'' and it already sounds much better. I'm debating on one of the Musway options for more power, but even with the stock amp it gets plenty loud. Just looking more for a DSP upgrade than anything, then eventually upgraded the stock sub.
23OBX2.7
AB Canada
2023 Bronco
B&O now?
Blakshukvw
Blue Springs, Mo
96 explorer, 99 explorer, 04 marauder, 23 bronco
Has anyone used anything besides a kicker key amp? I despise that brand. I’m a huge RF fan though and would love to use an amp by D’Amore engineering like the e660.5 to power everything. Has anyone successfully used anything other than the kicker stuff?
RynoRanger
Chuck
Gilbert, AZ
azbluey.com
2.7L Badlands NS 4dr
Claude helped
Alternatives to the Kicker Key 200.4 for 2021+ Bronco
AudioControl ACM-4.300
- most commonly cited direct swap
Closest comparison to the Key 200.4. Similar in size and mounts in the same locations (under the steering wheel, etc.). More powerful than the Key. The tradeoff is no built-in DSP, but with FORScan tweaks you can go without it. PlugNPlayKits has a harness kit for it.
Musway M4+ / Four100 - step up in power, slightly larger
120W continuous per channel. When split for the front daisy-chained speakers you're still getting ~60W each vs only 25W from the Key 200.4 - big deal if you've upgraded to aftermarket speakers. Fits under the driver's seat with room to spare but won't mount under the steering wheel. PlugNPlayKits also sells a plug-and-play harness for this one.
JBL DSP 4086 - DSP-equipped alternative
Has built-in DSP like the Key, which matters for correcting the Bronco's quirky rear pod signal issues. Available at Crutchfield.
AudioControl D-5.1300 - if you want to go 5-channel
One amp to handle everything including the tailgate stinger sub. More involved install but a much cleaner end result.
Worth noting: The Key 200.4 is purpose-built as a piggyback amp for factory or low-power speakers. If you've upgraded to aftermarket speakers (Kicker KS series, etc.), the Key is likely underpowering them. The Musway or AudioControl options are the better fit in that scenario.
23OBX2.7
AB Canada
2023 Bronco
As a newbie I tried Key200.4 in S550 Mustang convertible. It failed after three weeks and Kicker dealer was a pain. Had to reach out to Kicker corp executives who promptly dealt with it however the process was cumbersome and lengthy during which time I bought Audison APBit 8.9. (in classifieds).
The Audison was great, easy plug and play, easy to set up and tune. The addition of Kenwood 1000W sub amp and JL sub really brought the whole system to near perfection.
The Audison tel support was amazing, and newbie had no problems at all. The amp performed flawlessly
