Sherminiator
CNJ
2022 Ford Bronco Big Bend, 2024 Bronco Sport Big Bend
So, where do you live? Do you think a spark plug tip will still break a window? The intruder will now have your keys and your truck. Insurance will give you a pretty hard time for leaving keys in the truck.
Plenty of incidents where I live at where not so smart people leave their keyfobs in a Range Rovers and other luxury makes and poof the truck or car is gone.
There was even an incident where someone had a C8 Vette, parked in the garage, and the people broke into the garage, opened the door and drove off with it, because they left the fob in the car.
Mostly minors doing it because the sentencing isn't as harsh, but they are getting paid by an adult behind the sence.
Ksjrb03
Tx
F250
I was interested in getting the keypad after delivery, but with Fordpass App lock, unlock, and remote start it seems a bit redundant. Unless you don't want to carry anything at all I suppose like going to the beach.
Does the dealer have to program the keypad if you purchase after the fact?
You can program it yourself in a couple minutes, super easy. It is just a stick on.
FordPass app unlock, lock, remote start is nice, but is in no way a replacement for the keypad. Especially the scenario of running into the store quick and leaving the truck running. The app is laggy, it can take a couple minutes for your command to be sent.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
I would edit the post this didn't work it cranked right up.
Thank you. Do you mean it fired right up after you clicked the "unlock" button on the fob inside the vehicle?
What happens if you lock the vehicle with the keypad (with a key inside), but then you try to start the vehicle by just pressing the start button (I.E., someone hides the passive key inside the vehicle so a would-be criminal doesn't know it's there, and they just smashed the glass or something)
I ask because here is that the manual says:
Ford Bronco Keyless Entry Keypad (Trick) Screen Shot 2021-10-25 at 12.29.36
Which makes it sound like any key left inside when the vehicle is locked via the number pad (or any other fob) will not work to start the vehicle.
Bradley Thornton
Bradley Thornton
Bradley
Hattiesburg MS
What happens if you lock the vehicle with the keypad (with a key inside), but then you try to start the vehicle. (I.E., someone hides the passive key inside the vehicle so a would-be criminal doesn't know it's there)
The I locked the bronco with the keys in it using the keypad then mashed the brake and started the Bronco up.
Let me do a little more testing I had both keys in it. I'll try it one at a time and see if one key (Passive Key lets it not start)
Bronco4
Frank
Medford Oregon
2017 F350 CCLB
not trolling - but serious - I am thinking of getting the keypad as well. But my points are serious. Keys in a running car - from what I heard may not be covered by insurance as theft. Something to think about.
That being said - if you use the keypad - where can the keys be left, out of sight, that will not be sensed by the car if someone does manage to get in. In other words - where can I leave my keys in the car, and the car will not start because the key is not present.
Please don't force me to get the jab either. ;)
21BL2DR
JD
ohio
2021 BL 2dr, 2021 BB 4dr, 2022 BS 2dr, trifecta
if i lock my f250 or my explorer or my bronco by using the keypad you can break whatever windows you want. truck isn't going anywhere. the security systems in these vehicles are way more sophisticated. I have three fords that the keys never come out of. Keypad use only.
tn3sport
Tennessee
Ford 4x4, BMW, Mustang, several adventure bikes
The "factory" keypad, and the one you order from your dealer after delivery, are the exact same product.
Kinda... Factory model is hardwired with power. FoMoCo accessory is coin battery operated.
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Negative. Not on the Big Bronco.
It is just the battery one, programmed and stuck on at the factory.
(unless I missed an update)
mountainbronco
I can tell you it works in the center console
yes, because in the center console is an indentation, where you put your FOB when it's battery dies so you can still start the Bronco. So, the center console is the last place you want to "hide" your key when using the pad..........
Daktari
Oliver
I'll get it and stick it on the gas door, a neat option to have. Ford Pass App works too, cars stays locked with fob in side, but there's not always cell service where I might want to leave that bulky key inside.
Will be one of the first things I order from the parts counter when I get my first service.
FourHorses
Four Ford Horses and an Expedition
I do believe this is still accurate, but for MY22 it appears to be painted body color.
Mr_Scoutmaster
Austin TX
'22 Bronco Badlands / '22 BMW X5 45e M Sport
Also - this is a no go for me with a soft top.
MayhemMike
Mercury
Sometimes I just don’t understand you whippersnappers. It isn’t like you need a hand truck to bring your key or fob into your home. There is absolutely no upside to leaving the key or fob in the vehicle.
21BL2DR
JD
ohio
reading the manual is important. It helps owners understand how the system works. Thanks for posting.
TheWoo
Manhattan, KS
2021 Gladiator Mojave
Unless you don't have a place you like to carry it. I loved using my keypad on my F-150 every day at work. Fob in the truck. I didn't have to carry my keys in my pocket.
I'm no whippersnapper, I just don't like stuff in my pockets.
