Keyless entry keypad OEM
rdg04578
Everglades
Bob
Northern Maine
2013 jeep rubicon, F-150
Everglades
you could try to hack it ---if you have the previous owners zip code--try that it is a common 5 digit code
RedTailHawk
2024 Ford Bronco Raptor
Check your glove box. If the truck came with any paperwork there will likely be a credit card sized card in there with the code.
I just found the credit card size card attached to the fuse panel under the steering wheel...and my vehicle doesn't even have the numeric keypad. Any idea why I'd have a SecuriCode?
Ducati1098
This is already mentioned half a dozen times in the thread, but the SecuriCode has nothing to do with the Broncos stick on keypad.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
SecuriCode is part of the overall security system (PATS) built into Fords.
If the Bronco had a hard-wired keypad, that code would work for that keypad. But obviously the Bronco does not.
