subg
Illinois
2023 Base Bronco 2 Door
20x in, is it still crack free?
Yeah. Nothing yet.
Top getting wavy though. Looks like hail damage in one spot, but obviously not.
It's a 2023, so hopefully improved over 2021's.
Jebster
Honda ridgeline
That is the same setup I have for mine! Love the hoist I can remove the top by myself and reinstall it by myself. I like that it gives me some where to store the clam shell when it is off too.
I've been looking at the lange hoist but had a question. Having the hoist frame connect to the rear of the clamshell and then the front of the middle panel seems odd. Does this create pressure on the clamshell to middle panel joint? Seems like it would simply fold once you start lifting. I will admit I haven't had my top off yet so I'm not familiar with how those sections connect.
JimmyG
Greg
Ann Arbor, Michigan
Fords and Cadillacs
I use the top lift pro, ...Snip
Same here - Top Lift Pro + Rockworx. Made the PVC door storage from this forum. All 4 top pieces off plus 4 doors off and all stowed in about 20 min.
Get a Top-Lift Pro... All of the engineered ideas on here are awesome, but this thing just works.
Happycampinman
Ford Bronco
Nice write up, lots of useful information and innovation on everyone’s part. Makes be appreciative of our soft top though.
stickshifthappy
RVA
Ford Ranger, 65 Mustang
I have a ceiling mounted winch and a power ratchet with the torx bit (far less likely to bust a window in a rush). My 2 door top goes on/off in 10 min or less. I leave the top hanging from the ceiling when not in use. I park underneath it when it’s off.
You’re my hero !!!
subg
Illinois
I just realized that picture added to the thread header is someone taking their top off solo.
Not me btw, lol.
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
I took my rear top section off this spring and don't plan on putting back on till the snow flies. I have the ford tonneau cover and even though the rear is open I don't get any water inside. I've hod NO problems with the front three removable sections staying in place without the rear section at freeway speeds.
If I could find a rear canvas window for winter I would never put the rear section back on.
aggiedrew08
Andrew
Houston, TX
'23 Bronco 2.7L 4dr SAS
mikeeshim
Los Angeles, CA
MBZ E350, supposed daily driver
2) Put some rubber hose or tape on the wrench handle. At some point, someone is going to crack a window taking the rear screws on or off. I've made some scary noises not taking my time.
Take a look at these:
https://gpca.com/products/bronco-tie-down-anchor-pro
One of the first things I got, and makes the process a lot safer(for the windows) and extremely convenient.
Ilovebroncos
Bay area
Jeep Grand Cherokee 5.7L
Yes they have a rubber washer. They work great and are a must if you take the top off often. Make sure to get the two for upper roof bolts as well for completely toolless removal (they used to be sold separately, not sure about now).
I have them in red, they're awesome
TripleSe7en
Pittsburgh
2022 Bronco 2 Door, 1979 Pontiac Firebird Trans Am
I'm really looking for a fold-down soft top option for the 2 door. As nice as they've made it, removing the hard top is still too much of a PITA for me.
Chsbronco
Paul
Charleston
Made a hoist to lift the soft top off. Cost about $60 for 1/4 inch braided rope, 9 pulleys, 9 eye hooks, 3 ratch straps, and a 2x4.
darinhouston
Darin
U.S.
Bronco, Jeep Wrangler, Bronco Sport, Pallisade
8) Chase all 10 threads/weldnuts ASAP if you have a tap. Made things a lot easier going on and off.
What do you mean by this?
subg
Illinois
There are 10 holes in the body to mount a top on the 2-door. One of mine was partially cross threaded from the factory. Another one had way too much paint in it and was tight.
I took a M8 x 1.25 and hand tapped each hole to clean them out.
jp925
Ventura
2023 Big Bend, 2006 STi, 1974 Bronco
Noobie question, I pull my front panels off all the time on my 4dr. But for the life of me I can’t figure out how to easily pull the middle panel solo without dragging it or bumping it around. I’m 6ft, and can lift and maneuver it solo with easy once it’s off the truck…. But getting the top off….. any tricks I’m missing?
